30 Hr vs. 8Day - How to tell?
Discussion in 'Wood Movement Clocks' started by mtfinger22, Jan 28, 2008.
  1. mtfinger22
    mtfinger22 Registered User
    Jan 28, 2008
    50
    I have tried searching on this but can't seem to find my answer.
    I'm looking at picking up a clock. The person selling it is not sure if it's 30 hour or 8 day (the clock needs some help). It's spring wound, not chain driven.
    I thought there was a way of looking at the going train and determining if it's a 30 hour or 8 day movement.
    Here is a picture of the movement:
    How do I tell?
    Thanks!
  2. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    4,873
    153
    Devon
    Hi and welcome to the MB,
    A 30 hour movement will nomally have 3 wheels in the train while an 8 day one has 4. If in any doubt aqssuming it runs get them to wind it up and wait to see how long it runs. HTH.
  3. Thyme
    Thyme Banned
    Sep 18, 2006
    3,948
    metro NY area
    Measure the width of the spring. If it is 3/8", it is a 30 hour movement. If it is 3/4" or greater, it is an eight day movement.
  4. mtfinger22
    Jan 28, 2008
    50
    Thanks for all the great information!
    The owner of this clock sent me some additional pictures and gave me the layout of the going train. I believe it to be a 30 hour clock.
    Spring barrel gear - gear/pinion - gear/pinion - escape wheel/pinion = 4
    The post above says 3 = 30 hour and 4 = 8day. I think that assumes that you don't count either the spring gear or the escapement wheel. I just found something that says 4 = 30 hour and 5 = 8 day, but I think that includes both the spirng gear and escapement.
    Can anyone confirm the above information?
    The gear on the spring barel is directly driving the minute hand. I read somewhere else that this typically means 30 hour. All of my 8 days clocks have a gear/pinion combination between the spring gear and the minute hand pinion. I have 2 30 hour clocks and they both directly drive the minute hand off of the spring gear.
    I didn't get the width of the springs, but looking at the pictures they are around 1/2" or so (hard to guess). I don't see them being 3/4" or bigger.
    Is my determination of 30 hours sound right?
  5. Tom McIntyre
    Tom McIntyre Technical Admin
    Aug 24, 2000
    82,995
    1,715
    176
    retired SW dev
    Boston
    I cerainly have not seen all the clocks, but I have never seen an 8 day spring driven wooden works clock. I would be very surprised to see one made in America. Did they make such things in the Black Forest or elsewhere in Europe?
  6. mtfinger22
    Jan 28, 2008
    50
    The movement pictured is German (Black Forest).
    I don't know the answer to your question, but based on some information I found earlier today, *most* Black Forest wooden plate clocks (the workings are brass/steel) are 30 hour, but some can be 8 day.
    I'm not an expert. I just believe everything I read on the Internet!:eek:
  7. Mike Phelan
    Mike Phelan Registered User
    Dec 17, 2003
    9,836
    15
    West Yorkshire, England
    It is indeed a very common type of Black Forest clock, and is definitely 30-hour. You only have to look at the fact that the arbor on the countwheel pinion is next to the barrel.
    Earlier BF clocks had wood arbors, even earlier they had wood wheels and verge escapements.
    Avoid bushing mania on these clocks - a recipe for disaster!
  8. chrsvor25
    chrsvor25 Registered User
    Jun 16, 2005
    1,243
    30 hour springs are really small, don't take up as much space on the movement. and not as wide. 8 day springs are otherwise.
  9. Mike Phelan
    Dec 17, 2003
    9,836
    15
    Indeed that is so, chrs; they need more power for the extra wheel in each train.
