30 hour or 8 day wooden works
Discussion in 'Wood Movement Clocks' started by Frederick, May 20, 2015.
  1. Frederick
    Frederick Registered User
    May 24, 2003
    117
    Thanks to those who responded to my WW movement weights question. I have another question. The Hoadley movement (most likely) I have is apart. Before I send it out, and regarding the weights, how can I tell if it is a 30 hour or 8 day?
    Thanks. Fred
  2. R. Croswell
    R. Croswell Registered User
    10,503
    915
    I know of no simple way to tell by just looking unless you had and 8-day and a 30-hour side by side. 8-day clocks often have an additional wheel and pinion but may just have larger wheels. You can verify the runtime mathematically with some effort. Begin by finding the pendulum rate from a rate table or the pendulum formula, then counting teeth in the escape wheel determine how many times it will rotate in a 24 hour period, then count the gear ratios of the time train and determine how many times the main wheel (and the winding arbor) will rotate in 24 hours. If the main wheel turns several times in a 24 hour period you have a 1-day or 30-hour clock. The main wheel is limited in how many times it can rotate before the cord spool is full (only allow a single layer).
    When the clock is together and running it will be obvious whether the weights have any room left to fall after 24 hours. If it runs on less than 4 lbs. then it is likely a 30-hour clock, but be careful - if it is a 30-hour clock with pivot and bushing issues it may not run on 4 lbs. but might run on 8lbs. briefly before shedding teeth from the wheels.
  3. john e
    john e Registered User
    Apr 23, 2015
    365
    Electrical Engineer
    Long Island, NY
    "before shedding teeth"..
    Makes it sound so, "pleasant". What a nice way of putting it. I like it...;)
    John
  4. Jim DuBois
    Jim DuBois Registered User
    Gibbs Literary Award NAWCC Member Sponsor
    Jun 14, 2008
    2,962
    655
    Magnolia, TX
    #4 Jim DuBois, May 20, 2015
    Fred, photos of what you have would be very useful in answering your question. Right now I don't know if you have a shelf clock or a tall clock. It makes a difference! There are clues that could be ascertained from photos that might well allow one of us to assist in providing you with a good answer.....Hoadley 8 day shelf clocks in wood works are not common. Here are a couple of Hoadley tallclock photos, front of a 30 hr and back of an 8 day. Not real helpful but either is pretty easily identifiable. hoadley 30 hr ft.jpg hoadley 8 day.jpg
  5. Tinker Dwight
    Tinker Dwight Registered User
    13,666
    71
    Although, RC makes it sound difficult, you only need to count
    teeth between the minute shaft and the winding drum.
    You'd need the diameter of the drum as well.
    You don't need to now the pendulum rate or count all the teeth,
    just those between the minute shaft and the drum.
    If more than one wheel, all the pinion and wheels.
    The calculations are not hard and if you post your values,
    we will be able to tell you what you want to know.
  6. R. Croswell
    10,503
    915
    In deed that is a simpler better way!
  7. Tinker Dwight
    13,666
    71
    Being a recoil, it will most likely run, fast, without a pendulum
    attached.
    One can let it run for 15 mins on the dial and measure
    how far the weight has fallen.
    Multiply that distance 96 to get the distance in a day.
    I tend to be more an## and would count the teeth.
  8. john e
    Apr 23, 2015
    365
    Electrical Engineer
    Long Island, NY
    Remove the pallets, pull down by hand, go for a full round of minute hand. Mult by 24.
    John
  9. Tinker Dwight
    13,666
    71
    With reduced weight I hope.
  10. Frederick
    May 24, 2003
    117
    Thank you gentlemen. From Jim's pictures, I am sure my Hoadley tall case movement is 30 hour. Will proceed on that
    knowledge.
    Fred....
  11. Jim DuBois
    Jun 14, 2008
    2,962
    655
    Magnolia, TX
  12. john e
    Apr 23, 2015
    365
    Electrical Engineer
    Long Island, NY
    Hey, go easy on me. I am on a diet, it's just not showing yet..I have big bones..
    No weight, just by hand. And yah, it is important to not go crazy on the spin rate.
    John
