• Upcoming updates
30 Hour Long Case with Two Weights
wspohn
Feb 3, 2020
157
121
www.rhodo.citymax.com
Almost all of the 30 hour long case clocks I have seen operate with only one weight, but I have one that is a rope drive clock with two weights and independent ropes.
Is this possibly original or is it likely to be a later modification? The clock is c. 1800 and made in Wales.
wspohn
Feb 3, 2020
157
121
I don't but I can take some. It is a very conventional two handed brass dial clock (11" dial). I hadn't seen any two rope set ups before and just wondered if there was a way to tell what was original.
Jim DuBois
Gibbs Literary Award
Jun 14, 2008
4,048
1,647
Magnolia, TX
If there is a click wheel on both main wheels then it is a very good chance it started life as a two weight. I have had one such example in years past. If they, the click wheels and ratchets don't match then one might conclude it is a later "improvement" and that is certainly possible too....
novicetimekeeper
Jul 26, 2015
12,371
1,615
Dorset
Lantern clocks were originally two separate trains with separate weights (also wound in opposite directions)
That changed with the introduction of the Huygens loop system. The advantages are longer duration for the same height, and maintaining power.
179,914
1,569,462
54,316
edflaherty
911
3,090
