Help 30 Hour grandfather clock date wheel issue
Discussion in 'Clock Repair' started by Foggy19, Dec 8, 2019.
  1. Foggy19
    Foggy19 Registered User
    Dec 8, 2019
    Hi after owing my grandfather clock for some 35 years I have decided to strip and clean the movement, the date/ colander dial has never worked so I would like to resolve this, after removing the face i can see why there is nothing to drive the toothed date wheel, I have tried to search to see images of 30 hour movements to understand how it should work with no avail. Can any one kindly help want info appreciated.
    Regards
    Mike
  2. novicetimekeeper
    Jul 26, 2015
    9,151
    470
    Dorset
    As they alter a fair bit it would be better to give us pics of what you have, both the back of the dial and the motion work. 30 hour movements could be plated or posted frame, calendar wheels can be 31 internal tooth, 62 external tooth, the 62 tooth can be westmorland style set to one side or more conventional on the centre line from 6-12.
  3. Foggy19
    Dec 8, 2019
    F9301CF1-80B5-42F7-99A0-8A6EF89D2D57.jpeg 2F1183E7-79B7-4610-8DEE-C1DB9CDC6FF6.jpeg
    Hi thanks for reply it’s a 62 tooth date wheel pictures of movement and face hope this will throw some light on what’s missing regards
  4. novicetimekeeper
    Jul 26, 2015
    9,151
    470
    Dorset
    A 62 tooth date wheel needs a push every 12 hours, so there should be a pin or flag on a wheel that rotates at the same rate as the hour hand. Looking at your motion work there appears to have been a flag that has broken off.
    Foggy19 likes this.
  5. Foggy19
    Dec 8, 2019
    Thanks for quick response much appreciated, any idea where I could obtain a picture of the part you mention so that I can get my head around what’s missing and how it work? Once again many thanks
  6. novicetimekeeper
    Jul 26, 2015
    9,151
    470
    Dorset
  7. Foggy19
    Dec 8, 2019
    I have looked at the gears that operate the hands and it looks like there would have been a tooth that drives the date wheel but unsure were I could obtain one or get this repaired
  8. novicetimekeeper
    Jul 26, 2015
    9,151
    470
    Dorset
    You can buy wheels but you would have to make a flag or fix a pin yourself or get a clockmaker to do it. You can find an accredited repairer through the BHI but you may find the repair costs more than the value of the clock.
    Where are you in the UK? We may find someone on here not too far away.
  9. Uhralt
    Uhralt Registered User
    3,823
    376
    I believe in post #3 I see a small hole in the hour wheel, close to the center. Possibly there was a pin in this hole that has fallen out or broken off. If so, that pin should be easy to replace. From a meshing point of view this appears possible as the rim of the calendar wheel gets really close to the center hole of the dial, so this pin could be able to push the calendar wheel one tooth twice a day.
    novicetimekeeper and Foggy19 like this.
  10. Foggy19
    Dec 8, 2019
    #10 Foggy19, Dec 8, 2019
    Thank you for the post you are correct there is a hole Which I have found. Now I understand what I was looking for I have made a pin and soldiered it in and hey presto it works I would like to thank you for pointing me in the right direction, just need to clean and get it running the hammer action seems quite clunky great to get the date wheel sorted many thanks
  11. Foggy19
    Dec 8, 2019
    Nick thank you for your help I have now got it working, just need to clean it and try and set it up many thanks
  12. Uhralt
    3,823
    376
    You're very welcome! Glad it worked out for you.
