3 Pocket Watches
ILoveClock
Jan 9, 2010
20
Hi, we have 3 old pocket watches but have no idea what they are/how rare they are, one has been valued many years ago:
The first one is a 9ct Gold Mappin and Webb watch with Swiss Omega Movement, 1915 import. picture below:
http://i44.tinypic.com/8vuhc0.jpg
The second watch is an 'Ingersoll' watch, it says made in Gt Britain at the bottom, we are not sure what it's made of, picture below:
http://i44.tinypic.com/547w9x.jpg
The third watch is made of solid silver, but has no name on the face. It also has a nice design on the back of it, picture(s) below:
http://i43.tinypic.com/2e38x0o.jpg and
http://i41.tinypic.com/281an91.jpg
I will try to get some pictures of the movements up later, I am being careful with them as I don't want to break them...!
Could anyone shed some light on these? Many thanks
Kent
Gibbs Literary Award
NAWCC Silver Member
Aug 26, 2000
18,531
1,962
It would be helpful if you could post pictures of the movement (the "works") and markings stamped inside of the watch case (you can ignore any "hand-scratched" characters, they're watch repairers' marks), the clearer and sharper, the better. Directions for posting on this message board are below. Clearness and sharpness is important as differences in make or grade can be subtle. Other pictures will help a little, but these are the most important. We may be able to identify it by the shape of the plates. In trying to open the watch, you might find the information in the Encyclopedia article entitled "How To Open A Pocket Watch Case" useful.
You can test your efforts to post pictures in the Just Practicing and Learning Forum. If you have a problem getting the picture(s) to load, check your file size and make sure that it is less than 500Kb. If it is, it should load to be posted. Too large of a file size is probably the most common problem in trying to upload a picture.
Its also helpful if you can post all the markings that are on the movement (the "works"), especially the movement serial number, in case they can't be seen in the picture(s).
How To Post An Attachment
These directions for posting images sound difficult, but it takes longer to read them than to actually do it.
To post one or more images, click on the "+ Reply to Thread" button which will cause a "Quick Reply" box to open. When that happens, scroll down to just below it and click on the "Go Advanced" button on the right-hand side.
When the "Reply to Thread" box opens, you can create your post that will acompany the images.
To actually add images or other files to your post, again scroll down, a little further this time, and click on the "Manage Attchments" button. This will open a new page, the "File Upload Manager."
Click on the "+ Add Files" button in the upper right-hand corner. This will open the "Upload Files from your Computer" box.
Within that box, click on the Select Files button, opening the "Select file(s) to upload by mb.nawcc.org" box. Navigate within that box to select the image file on your computer that you'd like to upload. Repeat as necessary to select additional files.
After the files are selected, click on the "Upload Files" button.
Then, once all of the thumbnail images appear in the "Attachments" box at the bottom of the page, and after your text is complete in the "Reply to Thread" box, click on either the "Preview Post" or "Submit Reply" button below the "Reply to Thread" box.
Good luck,
165,478
1,440,500
86,255
ememess
2,873
