• The NAWCC Museum and Library & Research Center will reopen starting Wednesday, January 6, 2021 as per Governor Wolf's reopening mandate.
American 24 hr clock identification
JNasse
New Member
Oct 27, 2020
Hello Everyone,
My wife pick-up a 24-hour electric clock at a local flea market, and we are trying to identify the Maker, and restore to a working clock. It came without a cabinet and very few markings. There is a hand engraved marking that says "A 8-26-33" on the top brass plate and Hart and Hegeman MFG CO on what I think is driving the clock motion. I have attached several pictures of the clock and markings for everyone. I appreciate any information that you may have.
Thank you in advance!
IMG_0472.jpg IMG_0473.jpg IMG_0474.jpg IMG_0475.jpg IMG_0470.jpg IMG_0471.jpg
Peter
Jan 28, 2010
209
Bethlehem, Rural NW CT
Hart & Hegeman, located in Hartford CT, became Arrow, Hart & Hegeman in 1927, later became part of Cooper Industries. They were manufacturers of electrical switches and controls, and the brand still exists. Could be a general purpose time switch for lighting, traffic signals or whatever. Probably had a metal case or was mounted directly in an enclosure with the wiring and other controls. A nice piece of early electrical apparatus.
The piece with the chrome top and the white ceramic base is the switch.
-Pete
Toughtool
Aug 12, 2016
220
34
Panama City, FL
I would have thought the chrome top and white ceramic base was the drive motor, not the switch. It looks to me that the switch is here (photo). Clearly it is a contact set mounted to something insulated and movable, with wires going to its base.
However, it is marked like a switch. i.e. 5A @ 250 V, 10A @ 125 V. If it is a switch, where is the energy to run the gears from?
Peter
Jan 28, 2010
209
There was a similar switch with a knob on it in the cellar ofmy grandparents house (1892), relatively common with knob and tube wiring. There is a grey tin cylinder near the center of the second photo that could be an encased spring. There is a hole centered directly below it that could have been for a wind motor and the device which you pointed to (which does appear to be a switch) could have controlled the wind motor. Following along the train, I see an escape wheel and what looks like the support for a hairspring (missing).
-Pete
