2182 Accutron
Mike Kenley
Mar 4, 2002
664
Does anyone have a guess as to why a minute wheel in a 2182 Accutron would go bad? Teeth mangled and some teeth broken off.
Mike Kenley
Mar 4, 2002
664
doug sinclair
Aug 27, 2000
14,363
86
Calgary, Alberta
Mike,
There was a previous thread on the 218 (and related models) regarding hand problems that may shed some light on your broken wheel. I think the typical rust problem on these watches is your problem. You can see the previous thread
old ref::here.
Mike Kenley
Mar 4, 2002
664
Doug,
In other words the idler tube needs a small drop of oil where the minute pinion assembly slips on.
doug sinclair
Aug 27, 2000
14,363
86
Calgary, Alberta
Mike,
The minute pinion assembly (cannon pinion) is a two-part component on these watches. The actual pinion part is the part that drives the minute wheel. The larger wheel part of the assembly is driven by the gear train of the watch. When the hands are adjusted, the pinion turns within the clutch on its companion drive wheel. Is this the gear you said was stripped? The pinion part turns on the hollow idler post, and the two components (pinion and post) seize with rust. The minute pinion assembly must be removed, thoroughly pegged out, cleaned, the post glass brushed to remove the rust, and the idler post lubricated.
Since the minute wheel turns the pinion on the minute pinion assembly during hand setting, the minute wheel certainly could be damaged if the minute pinion had seized. That makes sense to me, but if you are shaking your head, I'll try again.
Mike Kenley
Mar 4, 2002
664
The part that is stripped is the minute wheel assembly and is listed as Part #580 in the Accutron, Series 218, service manual.
doug sinclair
Aug 27, 2000
14,363
86
Calgary, Alberta
Mike,
That is the minute wheel that is damaged. For that to happen, the pinion on part 579 (centre wheel assembly, somtimes called minute pinion assembly) must be frozen on the idler post. That minute wheel is quite robust, and I've never seen one go like that. Have you had the centre wheel assembly off? If it has seized, you will need to address that before you press a replacement part into service.
Mike Kenley
Mar 4, 2002
664
That's what is strange, the centre wheel assembly was not frozen. The damage was on the clutch wheel side part 208. But no damage to the clutch wheel!
Staff online
181,391
1,582,708
54,791
LSZ
3,130
Swiss Fake by Kent
Top
