218 Accutron Coil
bbwatch
Dec 25, 2002
270
I have a number of 218s which aren't humming. How can I determine if the coils or if the transistor are at fault?
BarryB
mrbill
Jun 5, 2006
652
It is easy to test the "CELL COIL" (the coil closest to the battery)
Simple volt Ohm meter and test for resistance. It will either test or
there won't be any reading, no reading, bad coil.
Cell coil good? Must be component coil bad.
bbwatch
Dec 25, 2002
270
Mr Bill - How do I know its not the transistor circuit instead of the coil?
BarryB
mrbill
Jun 5, 2006
652
This will only tell you where the problem lies in which coil assembly.
? R U repairing the transistor units? you could test from the component coil lead to where the very fine wire from the coil attaches.
Been so long since I've had an accutron apart not sure if you can find a test point from the lead to where the coil wire attached to the rest of the component coil.
Accutron Technician Cert. #1889
That was years ago ! 1975 at Joseph Bulova School of Watchmaking
Similar threads
S
Replies
13
Views
1K
C
Replies
Views
1K
collin
C
165,506
1,440,753
86,274
cicastol
2,873
