Simon Holt
I thought I'd share this with forum members because a quick search of the forum did not turn up any similar movements.
This clock came to me from a visitor to the Repair Café where I volunteer:
It's 17 inches high and is fitted with a high-quality 2-train movement by Winterhalder & Hofmeier. Brief research suggests it dates between 1850-1869, based on the maker's mark (W&H Sch.) There are two hammers striking two gong coils.
For me, the interesting thing is that it signals the quarters with a 'bim-bam' sequence ('bim-bam' at quarter past, 'bim-bam bim-bam' at half-past and so on) BUT the hour strike uses only one hammer. This is achieved by an extra lever on the front plate which is lifted by a pin on the hour wheel so that the outermost hammer is lifted just before the top of the hour:
(pre-cleaning)
And the reason I thought it was worth sharing is because of the two important aspects of getting this set-up to work:
1. The mesh point between the hour wheel and the canon pinion (I hope I got those terms right) must be just right, otherwise the lever will not be lifted as the top of the hour approaches
2. The pin on this lifting lever must be to the left of the corresponding pin on the outer hammer arbor (when looking from the front of the movement) otherwise the strike train will stall because it is trying to lift this lever as well as the hammer.
Needless to say, I'd rather you didn't ask me how I know...
Simon
(pre-cleaning)
Simon
