I recently acquired the two sided clock in the attached pictures. I think this is a solid bronze casting. Beautiful clock.
The original movement is in the clock but it was converted to 120 volt electric. The movement is not marked but it is pretty obviously a Seth Thomas 86. I have an 86 spring driven, one sided movement and I can use the components to revert the two sided movement to its original spring wound condition. My question is, when there is a hand shaft on both the front and back of the movement, where does the pendulum go? I had a two sided, thirty day ST 86 with a pendulum once but i can't remember how it was configured.
Any help would be appreciated. Thanks,
