19th Century 7.5 inch convex dial clock
novicetimekeeper
Jul 26, 2015
11,329
981
Dorset
Not without issues this one.
oversize winding hole and some adjustment to falseplate to make fit. Backbox has no dovetails, and cockbeading on bottom door is on the
case not the door. Surround side rails are both shaped but one is thinner and newer. Original was nailed, replacement screwed. Dial is very thin and poorly repainted.
Bezel looks like an early spun one, has a number of cracks. Movement looks ok but pendulum is homemade and crutch has been bent to suit.
Overall not my best buy but wasn't that expensive and will look much better when restored.
20210914_172229.jpg 20210914_172208.jpg 20210914_172303.jpg 20210914_172223.jpg 20210914_172159.jpg 20210914_174424.jpg 20210914_172351.jpg 20210914_172326.jpg 20210914_172937.jpg 20210914_172340.jpg 20210914_172312.jpg
Chris Radano
Feb 18, 2004
3,999
308
Pennsylvania
Yes but it's 7.5". Last I checked that is pretty small. When I see these small pendulum movement dial clocks, they seem to come 2 different ways. Either heavily used with chintzy homemade restorations..... or shiny, glaring brand-new looking restored.
daveR
Sep 10, 2008
373
12
melbourne, Australia
As you say with a bit of TLC it will come up well. What will you do with the bezel, repolish it a little or a lot or replace ? i am interested because of its cracks and as often happens with early 400 day spun all brass bases, the cracking can become quite severe from excessive polishing ( as the stresses are relieved, I believe)
david
Chris Radano
Feb 18, 2004
3,999
308
Pennsylvania
I have a stress cracked spun bezel on a Black Forest clock. I used silicone to seal the cracks from the back. No, I didn't gob it on. And then the glass also helps keep it rigid. This particular clock I think has small tabs to retain the lens. I know I used a modern material, and I've seen some crappy silicone clock bezel jobs. But this one I was proud of. The bezel is not easily replaced.
novicetimekeeper
Jul 26, 2015
11,329
981
Dorset
In this one the glass has fallen out though I have it. It seems to have been held in with a small amount of mastic. There are tabs to hold the glass but I agree a more permanent fixing of the glass would make the bezel more rigid.
I'll send the dial off for a repaint, something earlier may be found on it under the heavy finish, if not Ray and his date will have to go I think.
The surround is nice, the case will clean up, the hands are ok, it will look good on the wall.
Chris Radano
Feb 18, 2004
3,999
308
Pennsylvania
Since "Ray" is offset left, there was probably more to the signature that is now lost. Further, "R" could possibly be an interpretation of another letter, such as "A". The signature in it's current state may be only an erroneous result of interpreting whatever scant amount was legible to the dial strengthener.
novicetimekeeper
Jul 26, 2015
11,329
981
Dorset
Yes I agree, but if nothing can be found I think I'd rather go without. The Bezel is around 1860 on, the movement plates could be anywhere in a century, and the pillars Rose has as 1815. I have no idea where the 1843 on the dial is supposed to fit with that lot.
I think the bezel may be a later thing as the rest of the clock seems earlier.
168,146
1,466,311
48,110
Stevemn
2,955
