1950s(?) rare(?) Waltham wristwatch
bgallen
Mar 17, 2023
7
Hi all,
I recently inherited this Waltham from my grandfather, and I'm having some trouble identifying it, so I was hoping y'all could help. I actually bought Shawkey's guide to Walthams and I couldn't find it in there.
My guess is that it's pre-1957 because the manual wind movement has no shock absorber, and I am guessing '50s due to the style. But I really don't know. I'd like to get it serviced and a new crystal, but I need to find a new case for the (working!) movement because the back of this one is corroded.
Ironically, I found one on ebay to cannibalize and won it for $30, but the seller canceled it once they found they'd accidentally shipped it to someone previously in a mistaken order fulfillment. Haven't seen one since, and I've been looking for a year.
Any ideas would be very much appreciated! Thanks!
Jim Haney
Sep 21, 2002
7,663
3,066
73
Decatur, TN.
bgallen,
Welcome to the NAWCC Forums :)
WE would have to have a picture of the watch movement to help you out. You can pry off the back of the case to expose the movement and we need the information on it if you get a clear picture,. Thanks
roughbarked
Dec 2, 2016
668
347
While working for a company named Election, Fritz Marti began his research into protecting watches against shocks. In April 1928, he developed a so-called "unbreakable" watch, i.e. featuring a shock-absorbing system "with movable balance jewels".
In 1929 A first Swiss patent, No. 141098, was registered. This was the first system of this type and would later be used in the Incabloc ® .
On 2 March 1933, Portescap filed a new patent (Swiss patent No. 168494). By adopting a conical construction, centring precision now depended on Porte-Echappement Universel SA, and not on the blank manufacturer. This system proved to be the right one and production of the Incabloc ® began. The name Incabloc ® was registered and became a trademark on 6 July that year.
I don't think Waltham waited until 1957 to change the shock absorber.
bgallen
Mar 17, 2023
7
bgallen,
Thanks Jim! It's currently at the shop where my local guy is going to (eventually) Frankenwatch it into a broken Waltham I picked up cheap on ebay. Not optimal since he has to lathe out the replacement case and his lathe broke and needs a fix :/
I'll ask him to send me a picture of the movement next week and post it here, thanks for offering to take a look!
bgallen
Mar 17, 2023
7
Thanks, my assumption was that anything post 1957 would have definitely been incabloc, I have no idea of its actual vintage and was just guessing 1950s due to style. I'll try to get a pic of the movement next week.
Shawn Moulder
Sep 13, 2017
212
499
If it's American made it will most likely be a 6/0 movement. It will either be a 17 jewel or 21 jewel movement. The second hand looks very common to 6/0 movements from the late 40s or early 50s.
bgallen
Mar 17, 2023
7
Thanks Shawn, looks like you guessed it - - 6/0. Any way to narrow down the date and model based on the movement and the dial?
Thank you so much,
Blake
bgallen
Mar 17, 2023
7
Certainly a nice Waltham movt. I note that they made many variations of this movement. Does it have any numbers on the case? say A-11 or A-17, something like that?
Unfortunately I left it at the shop to be moved into a new case, as the current one has corrosion and damage to the caseback threading, and I don't have a picture of the back. I'll get one sometime and post it once I do.
bgallen
Mar 17, 2023
7
What resources would you all use to look this up and piece the details together?
Shawn Moulder
Sep 13, 2017
212
499
Your watch is definitely not military but is based on the same movement. Most military movements would be either 9 jewels, 16 jewels or 17 jewels. Toward the end of American made Walthams they ramped up production of the 6/0. I see a serial number on your movement but some numbers are blocked. Your watch looks to be made probably after 1945 to 1950. Your dial looks to be from the 1950s.
Shawn Moulder
Sep 13, 2017
212
499
Here is a picture from "A Collectors Gudie by Bruce Shawkey" that shows a Waltham from 1955 with a similar seconds hand and a dial with similar writing as yours.
bgallen
Mar 17, 2023
7
Thanks! Good call looking at the hands. I bought the Shawkey book hoping it would have it, but unfortunately this dial isn't in there. I'm going to assume ~1955 unless I find out otherwise, then.
Thanks all for your help!
181,444
1,583,169
54,815
matteo433
3,131
Swiss Fake by Kent
Top
