1929 Ingraham Mantel Clock Model #?
Discussion in 'Your Newest Clock Acquisition' started by dashley, Sep 10, 2017.
  1. dashley
    dashley Registered User
    Apr 30, 2015
    127
    Tennesse
    Hi,
    I've just purchased a Ingraham Mantle Clock at a local Flea Market. The movement was out of it and it looks like someone got quite a surprise when they took the nuts off the plates and tried to pull it apart. Two wheels slightly bent but all the pieces are there. The sprigs were completely unwound. The plate is stamped with the usual Ingraham markings 7/29, the mounting holes match up and age marks also. I'm going to go with that this movement belongs with this case. There are no labels on the clock to identify the model name. I've been to all my usual places online and can't pin this one down. Any hep identifying the model will be greatly appreciated.
    -dan
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  2. Steven Thornberry
    Jan 15, 2004
    17,981
    22
    It has the appearance of the Carmen as shown from the 1911 catalogue in Tran Duy Ly's book on Ingraham clocks (arlingtonbooks.com). It was 15" long at the base and 11 inched high. However, the Carmen was first offered in 1909 and last offered in 1914. Nonetheless, some discontinued models were carried on the price lists until the stock was depleted even though they were not shown in the catalogues. If this is the Carmen (do the dimensions match, even if not exactly?), this might be one of those discontinued models. See, for example, what I had to say about my Cabinet A in post 118 of the permanent Ingraham thread.
  3. dashley
    Apr 30, 2015
    127
    Tennesse
    #3 dashley, Sep 11, 2017
    Hi,
    Interesting information. Thanks. I've included the measurements in the image below. I'm not sure which is the standard way to measure so I've included a couple of reference points. I'm guessing to not include the feet in the measurement is the correct way. I so the measurements differ from those you mentioned. Perhaps the image below will help. Also added a couple of images that offer a better look at the pillars and clock case details.[​IMG][​IMG]
    Thanks Again
    -dan
    [​IMG]
  4. Steven Thornberry
    Jan 15, 2004
    17,981
    22
    The measurements you show are close enough to think it might be the Carmen. I have found that the catalogue measurements are often enough approximate, whereas the actual measurements of any model might vary somewhat from the catalogue measurements.
Similar Threads - Ingraham Mantel Clock Forum Date
ingraham mantel clock identification. Your Newest Clock Acquisition Aug 31, 2016
Ingraham Gingerbread Shelf/Mantel Your Newest Clock Acquisition Sep 27, 2015
Ingraham Mantel Clock? Your Newest Clock Acquisition Nov 19, 2014
E. Ingraham Mantel Clock Your Newest Clock Acquisition Oct 15, 2012
Ingraham Mantel with inlays Your Newest Clock Acquisition Nov 24, 2010
