Hello Folks - I have inherited a grandfather clock that I already gave the background on here on this earlier post - https://mb.nawcc.org/threads/grandfather-clock-information-please.176976/
The clock had been cared for and was running fine in all respects as of last summer when it was moved, by van, several hundred miles from my parent's home to mine. When we prepped the clock for that move we removed the 3 weights and all 5 chimes from the cabinet, as well as the pendulum. We also did some work to make sure the 3 pulleys that hold the weights were all the way up and secured so they couldn't move around during transit. The clock was lain on its back in the van and everything was done as carefully as possible. Eventually I went about putting everything back together as it was and got that done. And started the clock as normal - wound the 3 weights up to the top and pushed on the pendulum to get it going. Everything is working fine except for one thing. The far-right chime (designed as I understand it, for striking out the hour count at the top of each hour) is not doing anything at all (likewise the smallest weight, the one on the left side, which as I understand powers the hour strike, is not moving down at all).
I did check the level of the clock and it's off a bit but not by too much and I haven't gone through the steps to fix that. Also when researching this issue I did find some posts mentioning a possible root cause was over-tightening the small weight up too high. I really don't think that's the case - I wound it up as normal at my home after setting up the clock.
I've pasted several pictures below (more on the aforementioned link) specific to the parts of the clockwork involved here, at least as far as I can tell. In the first image the red box is around the mechanism which IF it would turn, seems to be what would trigger the hour strike. It's not moving at all during the top of the hour melody. In the 2nd picture below you can see the rest of that mechanism as it goes over by string to a hammer over there that would strike the far-right hour chime IF that were working. In the blue box you can see the hammer that would strike the far-right chime for the hour count. It's in the all the way back (farthest away from chime) position...and you cannot move that hammer manually at this point to bang that particular chime - there's no slack in that line to allow for it. In the red you can see that that piece is also on one extreme of it's range of movement (i.e. looking from the front of the clock, it can't rotate counterclockwise at all). So because the gears don't seem to be engaging for this small weight, it seems like none of this is moving.
Does anyone have any suggestions on how to get this hour chime working again? Thanks in advance.
Ben
Ben
