Working on restoring this John Fladgate, London repeater, I have discovered a missing part that helps operate the half quarter strikes. I have never seen this type of repeater system, even in books. I finally have the repeater running and the hours strike OK, but the quarters do not and there is an empty post in the critical operating position where a missing part used to go. I am hoping somebody here has seen one of these and knows the missing part operation. Because it is very unusual, it takes some explaining.
Here is a picture of the under dial repeater after some cleaning and adjusting:
What is very unusual is that the hammer trip dogs do not have the common return spring so the rack teeth can pass and then trip the hammers upon the return. Instead, the trip dogs are lifted on their posts so the rack can pass and then they are let down into operating position to contact the rack teeth when chimes are required.
The trip dogs (red arrow) are held up by the trip bar (blue arrow) which is spring loaded to drop down to let the trip dogs into strike position, but is held in the "up" position by the all-or-nothing strike lever (green arrow). When the repeater hour rack is reached, the strike lever (green) rotates counter clockwise, letting the trip bar push the trip dogs down into strike position. This all works, but then the strike lever is just loose on its post and leaves the trip dogs to strike every tooth on the hour and quarter racks as they pass. That lets the hours strike fine, but then always strikes all the quarters because the strike lever is doing nothing.
When it is set to strike quarters, the 7 tooth half-quarter rack (yellow arrow) falls correctly and would run the chime lever which lifts the trip bar that in turn lifts the trip dogs at appropriate times to strike or not. However, that sequence doesn't work because the strike lever is doing nothing.
The missing part in question goes on the empty post (red arrow) next to the strike lever. The strike lever can swivel too far out of place, but there is a hold for a missing post (blue arrow) that I am sure is a limiting stop for the strike lever movement. The notch in the end of the strike lever is a steep angle that lifts the end of the trip bar, moving the trip dogs up out of the way of the rack teeth as they pass.
The main problem is that when the quarters are striking, they always strike far too many strikes. By adding a new limiting stop post to the blue arrow and applying light hairspring pressure to the strike lever, the lever works to control the trip bar, but still lets far too many strikes run. This is because the quarter strike rack teeth are passing the trip dogs before the half-quarter rack teeth are engaged.
I am sure that whatever part was on the empty post (red arrow) must lift the end of the trip bar until the half-quarter rack teeth engage by the tang of the strike lever. However, it is a mystery what that part may be. Hopefully, someone here can help.
Doug Shuman
Doug Shuman
