1892 Seth Thomas 5-7/8 Plus 1/2 Movement
tommykat1
Dec 18, 2021
41
I'm in the process of restoring an 1892 Seth Thomas kitchen clock. It arrived mostly complete, but I'll need to fashion the alarm trip lever, as it was tossed years ago. So far, I've bushed, cleaned and oiled the movement, and it's been running in the test stand for a few days.
As the attached photos show, the nomenclature reads "5 7/8" with "1/2" underneath. I know that the first figure indicates roughly the pendulum length from top of ribbon to bob, but what does "1/2" refer to?
Also, is it safe to assume this is a number 44 movement? Neither of the lower plate ears have this stamp, as they do on other examples.
As always, thanks for your help!
Photos are prior to work performed.
17,155
3,007
On most S-Ts the number (5 7/8) would indicate the suspension rod length. From one end to the other, NOT counting the pendulum bob.
Your movement is a #44.
Duno about the (1/2), others may know.
tommykat1
Dec 18, 2021
41
On most S-Ts the number (5 7/8) would indicate the suspension rod length. From one end to the other, NOT counting the pendulum. Your movement is a #44.
Thanks, Willie. Anybody have an idea what the "1/2" means?
Dick Feldman
Sep 1, 2000
3,107
484
Colorado, usa
From your photos, it seems no bushings have been added to that movement in any critical places. If it is, as you say, 130 years old, it is inevitable the movement plates are worn, and probably at most pivot holes. Also, it seems the click assemblies are original. Those would surely need to be updated with that old a movement. Worn click assemblies can be a danger to the movement as well as the hand winding the clock. If you plan to "restore" the clock in a workmanlike manner, those are two things that should not be ignored.
JMHO
Dick
48,937
2,695
It COULD mean 1/2 turn of the main wheel per day? Just a guess. Your verge has been messed with in a bad way.
tommykat1
Dec 18, 2021
41
Yes, a prior repair person bent it, took two punches on the verge pivot hole, and three on the third wheel pivot hole. Yikes! All better now. Fully bushed and clock has been running steady for a week.
Alphonsus7
Aug 6, 2022
15
46
How did you fashion a new alarm trip lever? I recently came into the possession of an ST with the same missing arm.
Reactions: tommykat1
tommykat1
Dec 18, 2021
41
Alphonsus7, below is a closeup of the fabrication. I didn't have any kind of example to refer to. so I had to wing it.
I first tried .032 x .25" brass by about 2," (sorry, I didn't write down the length) but the end slipped off the alarm cam, even with a bend in it on the end. The solution was to use .064 x .25"
BTW, the shouldered setscrew is important. If your clock didn't have it in place (mine did), good luck finding one!
Here ya go:
20 Restoration, Fabricated Alarm Lever.jpg 21 Restoration, Alarm Lever, Attached.jpg 27 Restored, Door Open, With Movement.jpg
Alphonsus7
Aug 6, 2022
15
46
Here ya go:
View attachment 720856 View attachment 720857 View attachment 720860
Darn. I’m missing all three pieces.
tommykat1
Dec 18, 2021
41
Unfortunately, the pieces don't come up often for sale. I've seen some full movements with all the bits, but you'll pay a premium.
On a separate thread, another member went through the steps of fashioning both a trip lever and shoulder screw.
176,448
1,544,446
53,310
Toby2
1,064
3,031
