Simon Holt
I posted a query about this clock originally in General Clock Discussions (E N Welch Steeple Alarm clock: looking for date), in order to get it dated. I'm posting now in Clock Repair for guidance on a repair issue. If it's better to have one thread for one clock (regardless of the nature of the query) then maybe an admin would like to merge the two threads.
This clock came to me with a request to 'get it running again'. I don't know how many 150-year-old clocks there are out there that still belong to the original owner, but this is one!
Initial triage showed that, apart from being gummed with old oil and missing its alarm stop plate, the teeth on wheel of T1 show the following combination of wear and distortion:
The corresponding lantern pinion does not to seem too bad:
Before cleaning, the clock runs if the spring is more than half-wound. But does that wheel look close to causing terminal failure? Is it a suitable candidate for planishing?
I've seen that some people deal with tooth wear like this by flipping the wheel on its arbour. Am I right in presuming that this is not a candidate for this approach, give the fact that it carries the click arrangement?
As this is a 30-hour clock that sits on display in the local Freemason's lodge (the original purchaser) I imagine it will not be run much. So if there is some life left in those teeth than I'll leave them as they are.
Simon
Simon
