12 Inch Dial-What Diameter Glass To Repalce?
Discussion in 'Clock Repair' started by popeye, Jul 17, 2017.
  1. popeye
    popeye Registered User
    May 8, 2005
    1,459
    36
    I do have the bezel and would like to know is there a standard sixe replacment or do I measure bezel? If so from just before the back of clips?
  2. Willie X
    Willie X Registered User
    8,143
    32
    Carefully measure the bezel opening in the North-South and East-West directions and try to come up with a glass about
    1/8" less than the opening. If you have a cast bezel use the the smaller of the two dimentions, for a thin sheet metal (flexable) bezel you can average the two measurements.
  3. popeye
    May 8, 2005
    1,459
    36
  4. harold bain
    NAWCC Member Donor
    40,082
    45
    You will also have to determine if the original glass was flat or convex.
Similar Threads - Inch Dial Diameter Forum Date
IMB 15 inch 92956 Clock Repair May 20, 2017
Need help with a 4.5 inch Chelsea clock Clock Repair Mar 27, 2017
Waterbury Small (~ 2 inch) thin clock movement - escapement wheel needed Clock Repair Jan 16, 2015
10 inch no. 2 dial Clock Repair Nov 18, 2014
a Brillie Electric clock with a 6 inch dial Clock Repair Oct 26, 2006
