Click here to learn more about the National Association of Watch and Clock Collectors. Sponsor of this resource.Click HERE to join the NAWCC! NAWCC members may click on this button to log on to all NAWCC sites at once.
MB Rules
Library
Museum
School of Horology
FSW Program
4sale
Horology only please.
No For sale or Business Ads in Posts.
No Appraisals.
Go Back   National Association of Watch and Clock Collectors Message Board > Horological Education > American Pocket Watches
Reply
Thread Tools Display Modes
  #1
Old 11-13-2009, 10:22 AM
Jimbo76 Jimbo76 is offline
Registered user.
Default How to Deal With Rusty Hands
Hello, I have several sets of Hamilton hands that are rusty. Is there some way to refinish them or is there someone to send them to. Most are for 992 B and should be Black. I suppose paint wont do it ?
  #2
Old 11-13-2009, 02:37 PM
John Cote's Avatar
John Cote John Cote is offline
Default Re: How to Deal With Rusty Hands
I have had some success buffing the hands off with rouge on a buffing wheel. It is a pain but you can do it. Then clean the hands really well in ammoniated jewelery cleaner and rinse with water and dry them.
Then you get a piece of 1/8 inch brass plate/sheet big enough to fit over the burner of a gas stove and file a nice little pile of brass powder. Put the pile of brass powder on the sheet of brass and put it over the burner of a gas stove. Put one hand at a time in the brass shavings/powder so that the boss is submerged a bit. have a long tweezers in your hand and a bowl of water near the burner. Heat the brass plate and watch the hand turn colors. (The brass shavings are so that the hand heats evenly. If you don't do this the boss with heat more slowly.
The following is a chart of the progression of colors:
When the hands get to Dark Blue grab them out of the brass and dunk them in the water. The nice thing about this is that you can heat them over and over until you get them right. After you get them to the right color you can buff the blue off of the top of the boss and voila...a great set of hands.
__________________
John Cote
Past President, Indiana Chapter 18 - Membership Chairman, Chapter 149
  #3
Old 11-13-2009, 05:21 PM
Samantha Samantha is offline
Registered user.
usa us florida
A fiberglass scratch brush works great for removing rust, and then reblue them as John described.
Samantha
  #4
Old 11-14-2009, 10:07 AM
Don Dahlberg Don Dahlberg is offline
It is very important to get a good polish before bluing. I use white rouge. Then get it really clean. Finally, it is important to heat the hands evenly. Otherwise you get a rainbow effect with different colors at different locations on the hands. Heat slowly, so you do not have hot spots.
I made a bluing pan for hands and other items. It is a small piece of copper sheet attached to coat hanger wire with a wooden dowel handle.
Don
  #5
Old 11-15-2009, 11:42 AM
Registered user.
Thanks guys ! I will try this. It looks easy enough and I have a gas stove. Great information on this forum !
  #6
Old 11-15-2009, 03:33 PM
John Cote's Avatar
[QUOTE=Don Dahlberg;417202
I made a bluing pan for hands and other items. It is a small piece of copper sheet attached to coat hanger wire with a wooden dowel handle.[/QUOTE]
Don,
Thanks for the great pictures of your rig. Looks like I have some work to do. your way looks easier than mine.
__________________
John Cote
  #7
Old 11-15-2009, 04:41 PM
Registered user.
usa us florida
A small pan filled with sand will also provide a medium for even heat.
Samantha
  #8
Old 11-16-2009, 02:34 PM
BCMontana's Avatar
BCMontana BCMontana is offline
usa us montana
NAWCC
Quote:
Wow, A buffing wheel sounds difficult. I know if I tried that, the hand would likely be launched off the wheel and either become embedded into the wall, or even worse, into some vulnerable body part!
Have much more experience than I at such things, I really would like to hear how you manage to hold on to a small hand using a bugging wheel.
I have had success using finer and finer grits of wet/dry sandpaper. If the hands are really gunked up with rust, I start with #400. Just a few rust spots usually requires a little rubbing with #1000. Then you can polish the hands with #1200 and #1500 sandpaper to create a nice surface for bluing.
I place the hand on a ceramic tile, and heat it slowly with a heat gun. Then just like the other methods, plunge it into water when it reaches deep blue color. Obviously you need a heat gun which will heat up to 580-600 degrees, and I'm not sure if they all do this. I use a heat gun because I find it easier to control.
A similar method works for re-bluing screws.
  #9
Old 11-17-2009, 02:46 AM
HUDD HUDD is offline
Registered user.
i use the same method as B C Montana to blue the hands, but don't forget to pin small hands in place before using the hot air gun otherwise you could blow them away.
I use a home made bluing pan similar to Don's picture with some very small holes. This allows me to put a small panel pin through the centre boss of the hand and through the hole in the copper plate to loosely fix it.
This method of bluing as BCM says affords much better control of the bluing process. When the correct colour is obtained simply tip the hand with pin into a small dish of water or oil.
Hudd
  #10
Old 11-17-2009, 03:35 AM
Scottie-TX's Avatar
Scottie-TX Scottie-TX is offline
usa us texas
NAWCC
One tip you may like for removing the piece from the heat and process is a mechanic's magnet - a small pencil-like magnet, often on a flexible handle. This, you hold in your free hand, poised for that moment of color you want. It can quickly whisk the hand from the heat and to your oil or water with complete control of it!
Reply
Tags
deal, hands, rusty
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Rusty Elgin Hairspring bbodnyk American Pocket Watches 7 10-14-2009 12:42 PM
Rusty screws ChuckR 400-Day, Atmos and other Torsion Clocks 10 05-08-2008 04:53 PM
Rusty wheels and bad case blood sweat and gears Clock Repair 23 09-25-2006 06:29 AM
Rusty hands and green crystals Uncle Myer Watch Repair 6 10-04-2005 11:15 AM
Rusty staffs tbird American Pocket Watches 2 10-24-2003 06:21 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
copyright 2000-2010 NAWCC Inc.
