#1
Poblem -1877 keywind Waltham PS Bartlett serial #1699186 running well.
Sits in a deuber silver case. I be darned if I can find a place to change the time . Thier is only one key hole in back to wind watch . If you remove the watch from case I can not see any lever adjustment other than one small retangular hole with a flat pin in side it . If you push on the pin it seems to want to remove the face dial so I left it alone . If watch is in case it lays completely flat inside with no differance between the height of the case and the watch face or a place for lever set . One last thing watch seem to move inside case nothing securing it Stumped [img]null[/img]![]() ![]() ![]() ![]() [edit=5965=1171497343][/edit] [edit=5965=1171497380][/edit] |
#2
Your watch is a key wind/set. You set the hands with the same key you wind it with. Take a good look at the square the is in the center of the hands.
__________________
#3
Masseur LarFure
Thank you thank you thank you . ![]() I looked at every orifice on this watch with out even thinking about the center wind . Learning everyday. Thanks for putting up with the rookie Running Slow but still running ![]() |
#4
Be careful when you set the time. If you slip with the key, you can put a crack in your dial or destroy a hand.
You might want to take a look at this http://24.153.124.124/watchmaker/cwar.htm Don [edit=73=1171505995][/edit] |
| Tags |
| realy, stumped |
| Thread Tools | |
| Display Modes | |
