Click here to learn more about the National Association of Watch and Clock Collectors. Sponsor of this resource.Click HERE to join the NAWCC! NAWCC members may click on this button to log on to all NAWCC sites at once.
MB Rules
Library
Museum
School of Horology
FSW Program
4sale
Horology only please.
No For sale or Business Ads in Posts.
No Appraisals.
Go Back   National Association of Watch and Clock Collectors Message Board > Horological Education > American Pocket Watches
Reply
Thread Tools Display Modes
  #1
Old 02-12-2007, 04:15 PM
Tickie
Guest
Posts: n/a
Default Waltham "1877" calibre
Hello,
Can anyone tell me if the 1877 calibre waltham had a breguet balance spring fitted to it originally?
I have looked in the data base and it tell me that the watch was made in 1882. (Serial N° 1741948).
The way the regulator pins and the balance spring are seems to me to indicate it was originally fitted with a Breguet, but some body has put a flat spring in instead.
  #2
Old 02-12-2007, 05:55 PM
Tom McIntyre's Avatar
Tom McIntyre Tom McIntyre is offline
Administrator
usa us west virginia
NAWCC
Default Re: Waltham
The 1877 model was developed with a flat hairspring in all grades. Some of the late Appleton Tracy & Co. grade were fitted with Breguet hairsprings in the mid 80's.
Here are a pair of them from each group.
__________________
Tom McIntyre
  #3
Old 02-12-2007, 06:10 PM
Tickie
Guest
Posts: n/a
Default Re: Waltham
Thanks Mr McIntyre for your reply,
I have one of the early ones, no jewels, and to get the balance spring to sit between the pins, I must shape the balance spring into a bowl! Otherwise it misses the pins entirely! The pins barely come below the bottom of the cock, and for a flat hairspring this is rather scary
I did once come across a balance spring that had the last 1/2 of the last coil raised. It was NOT a Breguet, just the last 1/2 turn was raised. I never could find out if it was a one off by a watchmaker or not but I suspect it was.
[edit=6004=1171325505][/edit]
  #4
Old 02-12-2007, 06:35 PM
Administrator
NAWCC
Default Re: Waltham
Is the regulator curved like the first example I showed? If so, either the regulator pins are too short, or hairspring is colleted too low, which probably means the balance is not correct, etc.
__________________
Tom McIntyre
  #5
Old 02-12-2007, 06:40 PM
Tickie
Guest
Posts: n/a
Default Re: Waltham
The regulator is exactly like the first example. The reglator pins are to short but they do not appear to have been shortened. This is what threw me. I would have to bring the balance spring up to the base of the cock to get it flat
Reply
Tags
1877, calibre, waltham
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
copyright 2000-2010 NAWCC Inc.
