Click here to learn more about the National Association of Watch and Clock Collectors. Sponsor of this resource.Click HERE to join the NAWCC! NAWCC members may click on this button to log on to all NAWCC sites at once.
MB Rules
Library
Museum
School of Horology
FSW Program
4sale
Horology only please.
No For sale or Business Ads in Posts.
No Appraisals.
Go Back   National Association of Watch and Clock Collectors Message Board > Horological Education > American Pocket Watches
Reply
Thread Tools Display Modes
  #1
Old 02-10-2007, 01:58 PM
FredWJensen FredWJensen is online now
Registered user.
Default From Fusee to modern barrel
The fusee used a tapered chain winder to equalize spring strength differences as the spring unwound so that the movement was always subjected to the same force to insure steady motion. How is this accomplished on the typical barrels used after the end of the fusee?
  #2
Old 02-10-2007, 02:17 PM
Tom McIntyre's Avatar
Tom McIntyre Tom McIntyre is online now
Administrator
usa us west virginia
NAWCC
Default Re: From Fusee to modern barrel
The improvement in mainspring quality led to a longer and longer segment of the spring that provided an essentially constant force. In early high quality going barrels, stop works were used to restrict the spring to the linear portion. As springs continued to improve, stop works were discarded and only a recoiling click was needed to avoid the very short non-linear section. The extra bit of reserve takes care of the other end of the spring if the watch is wound daily.
At the same time improvements in the adjustment to isochronism allowed the watch to perform well with significant variation in power during the run of the watch. A properly set up balance is inherently isochronous, but the speed of the escapement changes with changing power and the escapement error will affect the time keeping. The overcoil is adjusted to compensate for the escapement error in very high quality work.
__________________
Tom McIntyre
  #3
Old 02-10-2007, 05:51 PM
Registered user.
That is great to know.
I am trying to build a crude verge watch, and the fusee is practicaly impossible to make without a fusee engine. I will substitue a standard barrel.
  #4
Old 02-10-2007, 06:12 PM
Administrator
NAWCC
Fred,
The verge is not a detached escapement, so it is much more important that the mainspring force be constant. If you can use a long spring with stop works you may be able to get it to keep some sort of time. It won't be any problem getting it to run, of course, only a problem to keep time.
You might want to compromise and use an existing fusee. The verge escapement is actually a recoil type escapement that is more dependent on the power than deadbeat escapements like the cylinder or duplex. It might be easier for you to start with a duplex than a verge.
__________________
Tom McIntyre
  #5
Old 02-10-2007, 08:05 PM
Registered user.
I guess I have to do my homework before I begin.
I really wanted to attempt to build a representation of the world's first pocket watch.
  #6
Old 02-15-2007, 11:45 AM
Registered user.
The Nuremburg Egg question turned up a great response from a German Gentleman. The German site actually had great photos and even a movie of the first pocket watch. It used a fusee. The fusee was amazing. Crude but amazing. It looked like it was filed by hand. And cat gut was used instead of a chain which was not invented yet. I may either try to file my own, or search for a large enough screw to modify for use as a fusee.
[edit=5941=1171561611][/edit]
Reply
Tags
barrel, fusee, modern
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
copyright 2000-2010 NAWCC Inc.
