#1
Several people in the past have asked about the red letters stamped in the inside back cover of late Hamilton watches. Tonight was Guild night and I remembered to ask a former Hamilton employee what these letters meant.
The answer is that they were a code for the date that the watch was cased. This was used when the watch was returned for service to see if it was still under warrenty. Now you know. Don |
#2
Very interesting and thanks for posting Don!
Now it's time for Terry, Charlie, Robert, Jim H., etc. to crack the code ... Fred |
#3
Thanks Don, did you get the info from Gordon?
For the cryptologists in our midsts I have an 945 (no s/n) in a Hamilton Star gold filled case with the s/n R975097. The red ink stamping is N-9. I believe this watch was toward the end of production (1969) as there is a 1970 dated presentation inscription engraved on the back. |
#4
Don,
Thanks for revealing more interesting Hamilton information. If it is ok with Don, This would be a great place to post all the different case codes that have been detected. Robert |
#5
Don & Robert,
Thanks for the information on these red "codes". I believe they started using these in the later years. I don't recall seeing any on 40's or 50's watches. Is this your opinion also? I had thought that the code was a simple one (Ex:A=January and the Year) , however A three figure code was posted recently that throws that opinion out.
__________________
Jim Haney |
#6
Jim,
I agree, from research, it appears that the codes were only in the cases near the end of production, i.e. late 60's. Do you have have any codes that you would care to share and what is the 3 digit code that was recently posted? Below are a few codes that I was able to locate. Robert "Courtesy, IHC 185" D-9---G-6---H-9---M-6---N-9---P-9 |
#7
Robert,
I think you need to match the codes with the movement serial numbers and the case serial numbers. Together, they make some sense. Of course, now that I know about the codes, I shall be keeping an eye out at the NAWCC Library and Research Center for a code sheet. Ron, yes Gordon was the source, as he so often is. Don |
#8
Don,
I have tried for some time now to decipher the codes, but no luck. It must be a very sophisticated date code with only two digits and now Jim informs us that recently a 3 digit code was posted. For example, P-9, assuming, A= Jan. etc, P exceeds the 12 months. If we consider, A to Z= weeks, the 26 letter alphabetic is not enough. With respect to the (year), the "9" could very well the the year (1969), since we only see these codes in the late 1960's. If someone could post a coded case, with a "known" purchase date, and all the info. i.e. case and movement serial numbers, maybe the "codes" could be deciphered. Robert |
#9
It was mentioned earlier about a 3-digit code, here we have one for someone to decipher. Have fun with this one.
Robert ![]() |
#10
I think you are looking in the wrong place. You need to talk to wristwatch people, particularly presentation watches. These are dated on presentation, so you know approximately when they were sold. If you get the code and presentation dates, you may be able to figure it out. Hamilton was big on presentation watches near the end. It was a major source of income then.
Don |
| Tags |
| hamilton, letters, red |
| Thread Tools | |
| Display Modes | |
