#1
I have an Illinois.. and all I can find out about them is the year...
This is what I have. Serial number: 5073365 on the movement: Victor Illinois Watch Co Springfield also: 21 Jewels |
#2
All that I can add to that is that it is a Model 1, Grade 279.
The "Victor" is apparently a private label. This watch was adjusted in three positions, temperature and for isochronism. 1928 is the production date. Is that what you have? I like those Illinois watches... smart looking. [edit=3350=1170943933][/edit] |
#3
Hello DADSTIMESHOP,
To add to what Tim T said, Russ Snyder's Illinois database CD shows 5073365 to be the following: Model...1 Grade...279 Size...12 Total made...16,000 over 20 runs, between 1926 and 1929. 5073365 was in a run of 300 movements from 1928, marked "Victor".
__________________
Best Regards, Larry Seikel |
#4
Hi,
Your watch is a 12 size 21 Jewel 279 grade run 3,073,301-3,073,600. The serial numbers and names I have to date there is only 300 made with this name, 16,000, 279 grade were produced. Jim Carroll
__________________
Jim Carroll |
#5
So its a Keeper
#6
Well... if you don't want to keep it - I will!
#7
Just remember that Illinois may have produced as many as 1,000 different private label brands. While many are fairly scarce only a few such as Ariston ,Benjamin Franklin,Penn Special,Santa Fe Special,Dependon and Interstate Chronometer etc command a premium
bob Schussel aka 12size |
#8
Can someone with access to the Illinois CD (I better get that thing!) run a S/N for me and give me the stats? All I have is a picture of a golden blob and the S/N of 1727191.
Thanks, Stan |
#9
Hi Bob -
If each of the different jeweler contracts are counted as a different private-label I think the total number might even be well into the thousands. Fred |
#10
Stan
according to russ Synders database your watch is a grade 183 16 size 15 j. About 13,600 were in a total of 14 runs Bob Schussel |
| Tags |
| illinois |
| Thread Tools | |
| Display Modes | |
