Click here to learn more about the National Association of Watch and Clock Collectors. Sponsor of this resource.
MB Rules
Library
Museum
School of Horology
FSW Program
e-Mart
Horology only please.
No For sale or Business Ads.
No Appraisals.
Go Back   National Association of Watch and Clock Collectors Message Board > Horological Education > American Pocket Watches
Reply
Thread Tools Display Modes
  #1
Old 02-07-2007, 10:21 PM
DADSTIMESHOP
Guest
Posts: n/a
Default Hamilton #'s??
I have a Hamilton that has the numbers 914 on the movement.. what does that mean... also the serial # 1839120 it says its a Lancaster? 17 jewels adjusted 3p
  #2
Old 02-07-2007, 10:42 PM
Robert Sweet's Avatar
Robert Sweet Robert Sweet is online now
Default Re: Hamilton #'s??
Hello DadsTimeShop,
You have a Hamilton, Model 914, open face, pendant set, 17 jewels, 12 size, adjusted to 3 positions movement.
Your particular movement was made in 1918. There were 43,099 model 914's made between 1912 and 1923.
According to a Hamilton reference, the 914 is larger than the conventional 12 size movements and requires a special made case.
Robert
  #3
Old 02-07-2007, 10:51 PM
DADSTIMESHOP
Guest
Posts: n/a
was 914 a model? I looked it up there are two 914 in the guide.. but how do you tell if its 14K? its says on the inside lid..."Hamilton" and then some design under that "Quality" and the the word "permanent"
  #4
Old 02-07-2007, 11:18 PM
rrwatch's Avatar
rrwatch rrwatch is online now
usa us georgia
NAWCC
The "permanent " marking on the case indicates that the case is gold filled , rather than solid gold. Just as the 5, 10, 20 and 25 year markings showed the length of time that the case was guaranteed not to wear through to the brass core underneath, the permanent cases were guaranteed forever, or at least until the manufacturer went out of business.
[edit=88=1170908331][/edit]
__________________
Ed Ueberall
The Escapement Home Page - Vintage Watch Restoration
  #5
Old 02-07-2007, 11:23 PM
Adding to Ed's nice comments.
Below is a Hamilton "Timekeeper", from abt. 1918 showing the 914 with the various cases available.
Robert
[edit=1315=1170909048][/edit]
  #6
Old 02-08-2007, 01:53 AM
Don Dahlberg Don Dahlberg is offline
A little on the three positions. A what has six positions, dial up, dial down, pendant up, pendant right, pendant left and pendant down. It talkes a great deal of engineering and adjusting to get a mechanical watch to run at the same rate in all six positions. It is easy to get the watch to run at the same rate dial up and down. You just have to make sure the two pivots (axles) that the balance wheel ride on are smooth and oiled properly. To get a watch to then keep the same rate in the pendant positions is much more difficult. You have to poise or balance the balance wheel like you balance the tires on your car. You also have to shape the hairspring so that is flat and a perfect spiral. Where the hairspring attaches to the balance and to the bridge that holds the balance has to be shaped just right. This was very labor intensive. A three position watch just meant that enough effort had been put into the movement to keep approximately the same rate dial up, dial down and pendant up. More expensive watches were five position adjusted, meaning they also kept to within standards in the pendant right and left positions. Some watches were good to all six positions.
Your watch is also a 12 size. In the mid to late 19th century the 18 size watch was popular. It is easier to make and adjust a large watch. That was a rather large watch. Through better engineering in watch and tool design they were able to mass produce 16 size watches of quality by the end of the century. By the 1920s and 30s the 12 size watch was the most popular pocket watch. Your watch was made as the 12 size was beginning to become popular. The catalog posted by Robert above tells how thin the watch is.
Don
  #7
Old 02-08-2007, 07:39 AM
terry hall terry hall is offline
NAWCC
Quote:
was 914 a model?
914 was a technically a grade rather than a model....
Reply
Tags
hamilton
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
copyright 2000-2009 NAWCC Inc.
