Click here to learn more about the National Association of Watch and Clock Collectors. Sponsor of this resource.Click HERE to join the NAWCC! NAWCC members may click on this button to log on to all NAWCC sites at once.
MB Rules
Library
Museum
School of Horology
FSW Program
4sale
Horology only please.
No For sale or Business Ads in Posts.
No Appraisals.
Go Back   National Association of Watch and Clock Collectors Message Board > Horological Education > Clock Case Restoration and Repair.
Reply
Thread Tools Display Modes
  #1
Old 10-20-2005, 05:59 AM
RJSoftware's Avatar
RJSoftware RJSoftware is offline
usa us florida
NAWCC
Default Buying shellac
Hello all;
Looking for advise on where to buy shellac. I want the best bang for the buck.
I have several clocks that I know I would love to restore with new coats of shellac.
I understand that I should probably try to get orange dewaxed shellac (after reading a few of craig's post).
Any ideals on how much I should try to aquire for about 4 clock cases. (2 ogee's and 2 mantles).
Also seems to be some confusion about water mix vs alcohol mix. (If alcohol does it have to be de-natured alcohol?).
Also if someone could comment on the cut ratio again, it would be apreciated.
Thanks in advance.
RJ
__________________
BEWARE OF ANGRY MAINSPRINGS...!
http://mb.nawcc.org/showthread.php?t=64121
  #2
RJSoftware's Avatar
usa us florida
NAWCC
Hello all;
Thanks in advance.
RJ
__________________
  #3
Old 10-20-2005, 06:02 AM
RJSoftware's Avatar
usa us florida
NAWCC
So far ebay has seller with orange dewaxed for 1 pound for just under $20 including shipping.
RJ
__________________
  #4
Old 10-20-2005, 08:32 AM
Scottie-TX's Avatar
Scottie-TX Scottie-TX is offline
usa us texas
NAWCC
"RM", Robert Fullerton recommended to me http://www.homesteadfinishing.com and to you I recommend the same. My 1lb. bag no. 1016 cost $18. Of course any respondent may feel free to expostulate on "cut" but if ya wanna just "cut" to the chase - here: I haven't abandoned my project Robert. I have all the materials and am still looking forward to it. ROBERT! Any feel for applying shellac with spray apparatus?
old ref::http://nawcc-mb.infopop.cc/eve/forums/a/tpc/f/57460...051078951#5051078951
  #5
Old 10-20-2005, 08:48 AM
lamarw's Avatar
lamarw lamarw is offline
usa us alabama
NAWCC
Concur with the source Scottie-TX gave you. You may want to also include in your order the Shellac-Wet since it really helps when you add to the mix. I use a plastic squeeze bottle to mix mine in. I used an old 12 oz plastic bottle that contact lens saline solution came in. Dry it out thoroughly. My formula is 2 ozs. orange shellac, 8 ozs. denatured alcohol and four or five drops of shellac-wet. I think Homstead is the only place with Shellac-wet. You may want to read what they say about shellac-flat; although I have not used it. Don't forget your rubbing or buffing stuff like medium course & fine pumice and rottenstone. The paraffin oil is good for using with the buffing powders and even with wet 400 or 600 grit sand paper. I think Homestead has all that stuff.
  #6
Old 10-20-2005, 10:11 AM
TomT TomT is offline
The strengths (cuts) of shellac most commonly used for wood finihshing are the one-pound, two-pound and three-pound cuts.
A one pound cut is simply one pound of shellac flakes added to one gallon of alcohol. That is 16 oz (by weight) of flakes to 128 liquid-oz of alcohol. A two pound cut is (obviously) 2 pounds of shellac to one gallon of alchohol.
A gallon is just too much shellac to mix at one time so a more practical mixture is 8 liquid ounces.
The mix for various cuts is as follows:
1lb cut: 1 oz flakes to 8 oz alcohol
2lb cut: 2 oz flakes to 8 oz alcohol
3lb cut: 3 oz flakes to 8 oz alcohol
Normally, a 2 or 3 lb cut is used for finishing stripped or previously unfinished wood. It is thicker and fills grain faster.
The 1lb cut is usually used as a finish coat. It is thin, goes on nicely but doesn't do a lot of filling. It's a good cut for your final polishing.
As far as alcohol goes, the best you can find is worth using. It makes application easier.
Basic Denatured alcohol can be bought at home stores and paint stores. A better quality shellac solvent is often available from suppliers of flakes. The difference is that the better stuff has less water in it to begin with so last longer.
Don't skimp on the quality of shellac flakes or the alcohol you use. A mix of shellac goes a very long way so your cost to finish a clock is actually very low even with the best flakes and alcohol.
A final note, don't mix more than you will actually use in a week or two. Once mixed, the shellac will absorb moisture no matter how tight you seal it. Alcohol is, by nature, hygroscopic. It loves to absorb water.
I usually only mix 1/2 oz of flakes with 4 oz of alcohol. This will usually do a case for me with a fair amount left over.
Once you begin to use fresh mixed shellac, you will never want to use anything else........
  #7
Old 10-20-2005, 10:19 PM
RJSoftware's Avatar
usa us florida
NAWCC
Thanks Tom T; Excellent post.
RJ
__________________
  #8
Old 10-20-2005, 11:08 PM
Robert M. Robert M. is offline
Scottie ole buddy,I've never applied Shellac with a spray gun but I certainly think its doable.I would imagine you would want your cut pretty thin,say one pound or a pound and a half cut to facilitate the spraying process.Personally I would also recommend the Shellac-Wet for wetting out the sprayed Shellac.Only my own opinion but I believe Shellac-Wet probably started out as an aid in spraying Shellac based on what I read on a wood refinishing site a while back.
I hope this answers a little bit of your question ole buddy.Thanks for asking,great question.
Respectfully,Bob Fullerton
Reply
Tags
buying, shellac
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
copyright 2000-2010 NAWCC Inc.
