Click here to learn more about the National Association of Watch and Clock Collectors. Sponsor of this resource.
MB Rules
Library
Museum
School of Horology
FSW Program
e-Mart
Horology only please.
No For sale or Business Ads.
No Appraisals.
Go Back   National Association of Watch and Clock Collectors Message Board > Horological Education > Reverse Glass and Dial Painting.
Notices
Reply
Thread Tools Display Modes
  #31
Old 11-04-2009, 06:53 PM
Jeff Monti Jeff Monti is offline
Default Re: stabilizing a reverse painted tablet
Malkin
Lacquer thinner does not usually contain MethyEthylKeytone. Some might but the majority available through retail outlets no not. Most lacquer thinner does contain Naphtha, Methonal, Acetone, and Toluene. To these standard ingredients different manufactures add any number of other solvents although the basic 4 usually make up at least 90% of the mix.
MEK is not a mix but a single chemical and is a highly caustic solvent that is very effective on a wide range of materials. It is in fact a much more powerful solvent than lacquer thinner. If you acquire any be sure to wear gloves and eye protection when using it.
Jeff
Contrastare la disinformazione, un posto in un momento.
  #32
Old 11-04-2009, 11:13 PM
Thyme's Avatar
Thyme Thyme is offline
Quote:
Originally Posted by Jeff Monti View Post
Malkin
Jeff
The blend can vary, but typically it does include MEK:
http://householdproducts.nlm.nih.gov/cgi-bin/household/brands?tbl=brands&id=16009004
Also:
http://www.kayakforum.com/cgi-bin/Building/Archive60.pl/noframes/read/63213
Traditionally, it usually did. My guess is that the more modern variants might not.
  #33
Old 11-05-2009, 12:17 AM
The EPA has gone back and forth on MEK. They put it on the HAPs list (hazardous air pollutants) then when most of the manufactures had removed it from their formulas they took it off the HAPs list (2005). I suspect that because it is so widely used in so many industries that some economic pressure was applied to get it removed. I know that you are thinking “our government would never allow something that was bad for the environment to go on just so they could make a few bucks” but I think it does happen on occasion.
It is a powerful general purpose solvent but if you are going to use it you should read up on the safety procedures. Its vapors are harmful, it is a strong skin irritant, and if you get it in your eye it will burn and if not treated correctly can blind you. That being said it sounds like it would be well suited for use in the Pettenkoffer Process. If you could find a place to buy it.
Thyme,
The MSDS you referenced for Parks lacquer thinner was effective 1997-05-01. It is out of date. Like most others they removed the MEK from their formulation and even after it was removed from the HAPs list never added it back in.
Jeff
Non è possibile salvarli tutti.
  #34
Old 11-05-2009, 07:12 AM
adrian adrian is offline
Quote:
Originally Posted by Thyme View Post
(Unfortunately, some here are disdainful of Krylon sprays, so it was encouraging to find an independent article endorsing their usefulness.)
I can understand that - it seems especially inappropriate on an 18th or 19th century clock, whereas a sixties pinball isn't so bad .. even though a replacement may be equally difficult to find.
An interesting part is the use of saran wrap to hold the paint down whilst not sticking to it yourself. I see some articles here refer to wax paper, which I suspect is a better choice for ease of removal, but harder to see what you're doing.
For what it's worth, this product seems to be a particular combination of solvent and varnish that works. Just any old sealant (or, unfortunately, another formulation from the same company) may be less good.
I'm very interested in the fuming approach myself - I like the idea of getting the paint to stick back down without adding a varnish, which I'd prefer to add only after the paint is all repaired.
  #35
Old 11-05-2009, 02:54 PM
Thyme's Avatar
From what we read here, using MEK alone was not always effective.
As for buying it, I don't know where you are located, but it is readily available in NY.
They may have if the hazardous status was repealed. Again, lacquer thinner has no rigid definition of formula, and it varies widely according to the manufacturer.
  #36
Old 11-05-2009, 06:27 PM
Steven Thornberry's Avatar
Steven Thornberry Steven Thornberry is offline
Moderator
usa us maryland
Interesting technique. I've used Krylon acrylic on dials to halt and reverse minor flaking successfully. But I use the UV resistant matte type, because it is invisible after application. As he said, (and as I've found) multiple coats can be added if you don't prefer to use the triple thick version. (Unfortunately, some here are disdainful of Krylon sprays, so it was encouraging to find an independent article endorsing their usefulness.)
I'll add my endorsement. I've used Krylon Acrylic Crystal Clear flat on dials with good results. I've never used more than two coats.
__________________
Reply
Tags
painted, reverse, stabilizing, tablet
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Removing paper from painted side of tablet mrclockman Reverse Glass and Dial Painting. 4 08-02-2009 10:44 PM
Stabilizing painted finish Doug Henry Clock Case Restoration and Repair. 4 03-22-2006 01:53 AM
Painted Tablet Restoration Sooth Clock Repair 7 08-19-2005 02:45 PM
reverse glass tablet conservation fume happy Reverse Glass and Dial Painting. 7 05-30-2005 09:35 AM
Reverse-Painted Glass wes cobb Reverse Glass and Dial Painting. 2 09-29-2002 06:24 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
copyright 2000-2009 NAWCC Inc.
