Click here to learn more about the National Association of Watch and Clock Collectors. Sponsor of this resource.Click HERE to join the NAWCC! NAWCC members may click on this button to log on to all NAWCC sites at once.
MB Rules
Library
Museum
School of Horology
FSW Program
4sale
Horology only please.
No For sale or Business Ads in Posts.
No Appraisals.
Go Back   National Association of Watch and Clock Collectors Message Board > Horological Education > Watch Repair
Reply
Thread Tools Display Modes
  #1
Old 11-03-2009, 08:55 AM
Melus28 Melus28 is offline
Default Hamilton
I have been having trouble getting this watch to run properly.
The problem is that the balance wheel moves freely, The staff, roller jewel, and hairspring all seem to be fine. The balance wheel seems to be 'centered and not touching the watch. The fork has power and seems to be 'poised' correctly, but I suspect this may be where the problem lies. The balance goes back and forth a few times, and just before it sets itself into a proper rhythm, the balance seems to get 'stuck' at about the bottom of the swing to the left. About '7' o'clock.
The model 987S has no poising screws, just a 'split' at both ends of the pallet to open or close.
Any suggestions as to my next step?
kind regards
Melus
  #2
Old 11-03-2009, 02:50 PM
Jtrenalone's Avatar
Jtrenalone Jtrenalone is offline
Default Re: Hamilton
Hello Melus,
If there is no apparent cause for the balance to stop, the first thing I would do is remove the pallet fork, and hairspring and install the balance alone. Then see if it spins freely in all positions. If so, re-introduce the hairspring, and check again.
By doing this, you can better isolate the problem,
Hope that helps,
Joel
__________________
Joel Trenalone
www.timepieceshoppe.com
  #3
Old 11-03-2009, 06:33 PM
Don Dahlberg Don Dahlberg is offline
I would follow Joel's advise, but before putting the hairspring back return the pallet and run the watch without a hairspring. This is called "half-timing". A watch should run for several seconds without a harispring. If not, something is binding or you are losing energy somewhere.
Don
Reply
Tags
hamilton
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
1930 Hamilton Cambridge vs. 1930 Hamilton Byrd... Tom Diss Wrist Watches 8 05-02-2006 04:58 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
copyright 2000-2010 NAWCC Inc.
