Click here to learn more about the National Association of Watch and Clock Collectors. Sponsor of this resource.Click HERE to join the NAWCC! NAWCC members may click on this button to log on to all NAWCC sites at once.
MB Rules
Library
Museum
School of Horology
FSW Program
4sale
Horology only please.
No For sale or Business Ads in Posts.
No Appraisals.
Go Back   National Association of Watch and Clock Collectors Message Board > Horological Education > Clock Repair
Reply
Thread Tools Display Modes
  #1
Old 11-03-2009, 01:59 PM
chezwilly chezwilly is offline
Default Hairspring adjustment
Hello,
I have a mantle clock with a hairspring. The clock is running fast and the lever on the hairspring is adjusted as far as possible to the slow side. Does anybody have any ssuggestions on how to slow this clock down?
Chez-willy
  #2
Old 11-03-2009, 02:22 PM
harold bain's Avatar
harold bain harold bain is online now
Moderator
canada ca ontario
Default Re: Hairspring adjustment
chezwilly, this problem is usually the result of a loss of power. Cleaning and checking (replacing if needed) bushings on the clock movement will often fix this problem, by giving the balance wheel a more healthy kick.
__________________
"Do not go where the path may lead. Go where there is no path and leave a trail" RWE
  #3
Old 11-03-2009, 03:25 PM
Thank you, but I failed to mention that the clock had a complete overhaul and repairs were made as necessary.
Willy
  #4
Old 11-03-2009, 03:43 PM
Moderator
canada ca ontario
If there is any extra hairspring past the pin, you could try lengthening it. First check that the coils don't touch, and no oil is on them.
__________________
  #5
Old 11-03-2009, 11:10 PM
shutterbug's Avatar
shutterbug shutterbug is online now
us iowa
The thing is that the clock used to run with the spring as is, and probably in a near center position. If it doesn't now, something is wrong. I think you need to take it apart again, check all pivots and holes and make sure everything is easy to move. Oiled were needed, and dry everywhere else. Trying to find a band-aid might come back to bite you later
  #6
Old 11-04-2009, 04:44 AM
bangster's Avatar
bangster bangster is offline
usa us utah
Shut's right. Lengthening the hairspring should be a last resort. Look for the power-robber. Friction somewhere? Slightly bent pivot? Maybe even a tired mainspring. Check the balance-staff cups (or jewels) to make sure they're not gummed up with misplaced oil, causing drag.
bangster
__________________
When estimating labor, remember Zipf's Law (aka Zifp's Law): Everything takes twice as long as you think it will...even if you take Zipf's Law into account.
  #7
Old 11-04-2009, 08:50 AM
Moderator
canada ca ontario
If the clock was overhauled, as Chez said, the hairspring/balancewheel would have been removed for cleaning. It may not have been repinned in the same position.
__________________
  #8
Old 11-04-2009, 09:36 AM
bangster's Avatar
usa us utah
Quote:
Good point.
But shouldn't the repairman have checked the rate before returning it? I always do.
__________________
Reply
Tags
adjustment, hairspring
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
Help with pallet adjustment adehuxley Clock Repair 4 08-22-2009 10:45 AM
Watch Adjustment Tom McIntyre American Pocket Watches 5 04-22-2009 03:13 PM
Beat Adjustment Steven Thornberry Clock Repair 5 06-07-2008 05:24 PM
Esc. adjustment Bob Reichel Clock Repair 8 02-18-2003 07:27 AM
adjustment positions John Cote American Pocket Watches 2 09-10-2002 03:30 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
copyright 2000-2010 NAWCC Inc.
