Click here to learn more about the National Association of Watch and Clock Collectors. Sponsor of this resource.
MB Rules
Library
Museum
School of Horology
FSW Program
e-Mart
Horology only please.
No For sale or Business Ads.
No Appraisals.
Go Back   National Association of Watch and Clock Collectors Message Board > Horological Education > The Construction of a Skeleton Clock.
Reply
Thread Tools Display Modes
  #11
Old 10-25-2009, 01:21 AM
Scottie-TX's Avatar
Scottie-TX Scottie-TX is offline
Moderator
usa us texas
Default Re: Another Skeleton Foliot BUCO
Gonna hafta work on yer sentence structure Pee-Tah:
"Work", here is not a noun such as, I've got "work" to do.
This, "work" is a verb - an operative - a nice thing - such as performing procedures, etc. SHEESH!
Gotta go and operate on my RESCH!
  #12
Old 10-25-2009, 07:09 AM
leeinv66's Avatar
leeinv66 leeinv66 is offline
australia au tasmania
Quote:
Originally Posted by Scottie-TX View Post
You mighta, Pee-Tah; You mighta seen 'em. They're to secure the thread suspension. Insert thread in hole and shove in taper to trap and secure thread.
No Scottie, I haven't come across that set up, but it sounds like a nice way to hold the thread.
Yep, work can be a noun or a verb depending on how it’s used. But, it will all ways be a four lettered word to me
__________________
Cheers
Peter: AKA (Pee-Tah) from Australia
  #13
Old 11-02-2009, 10:29 PM
Scottie-TX's Avatar
Moderator
usa us texas
Need only now to make hour hand and soon will.
Wag arm weights finished. Wanting them to be unique, I made them of square brass stock, antiqued chemically. Then drilled and tapped 4/40 for two thumbscrews I found in partz box. Slotted wag arm and now has weights and attachment unlike any on market.
  #14
Old 11-03-2009, 01:01 AM
Scottie-TX's Avatar
Moderator
usa us texas
Here, the structural change at bottom, elimination of lower pillar, and dial mount. I cut off the back plate where I removed the pillar. That left a scar on the wood that I covered with a very old, wood ornament. The lowest pillar was replaced with a dowel to mount the new dial further down because this dial, 8", is much larger and literally surrounds the clock like a halo. Again, the dial is a larger embroidery hoop. Now the dial has a three point mount, notched to top plate pillars and secured at bottom post! Remaining only now is it's hour hand.
  #15
Old 11-03-2009, 04:58 AM
leeinv66's Avatar
Nice work Scottie, very nice! I can't wait to see a picture of the completed clock.
__________________
Cheers
  #16
Old 11-05-2009, 12:46 AM
Scottie-TX's Avatar
Moderator
usa us texas
Gonna call this one done. Very pleased with it - like it better than the first. Hour hand was made from WENGEWOOD - a nearly black wood with bold striated grain. Not good for precision work as it chips easily, but I like it for this hand:
  #17
Old 11-05-2009, 02:25 AM
Scottie-TX's Avatar
Moderator
usa us texas
I really like the halo effect of the oversize dial. Hung and tested for th' first time, has met if not exceeded expectations. ( kicks hiney ) So here, it's unveiling: BUCO, Halo Edition - Behold!
  #18
Old 11-05-2009, 03:38 AM
leeinv66's Avatar
Kool Scottie, very kool! Yes, the oversize dial works well and makes you focus on the expose wheel work. Very nice indeed!
__________________
Cheers
  #19
Old 11-05-2009, 07:50 PM
Scottie-TX's Avatar
Moderator
usa us texas
. . . . . . . and here, th' twins!
What next? Hmmmmm; Mebbe a one wt. Wiener!
Reply
Tags
buco, foliot, skeleton
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Thread Thread Starter Forum Replies Last Post
A Simple Foliot Skeleton Scottie-TX The Construction of a Skeleton Clock. 12 10-14-2009 12:01 AM
Buco CH-9444 stratplus Clocks 8 08-02-2009 11:44 PM
Buco 1320 trebilroad Clock Repair 5 07-28-2009 06:13 PM
Let's restor a BUCO 1320 foliot Scottie-TX Clock Case Restoration and Repair. 39 06-16-2009 07:02 PM
Buco/Baumann foliot info Scottie-TX Clock Repair 4 04-09-2005 11:42 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
copyright 2000-2009 NAWCC Inc.
