NOTICE Notice: This is an old thread. The last post was 1558 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 3 of 3
    Default Antique 40's French ceramic mantle clock.
    I purchased this clock at "junk stand" but it is missing the winder, which should be quite long, but does somebody know the exact one in question? Also, could someone tell me more about the clock? I did some research and saw ones with a matching set of candelabras with the same style to them. The dial is marked "MADE IN FRANCE". Any imput would be great! Thanks!
    Regards.
ID:	167701   Click image for larger version.
    Registered user. volfghan's Avatar
    Mar 2012
    Smyrna / Turkey
    27
    Default Re: Antique 40's French ceramic mantle clock. (By: Ticktocktime100)
    clockarium has most of the informations about art deco faience / ceramic clocks. You may want to check this website.
    Default Re: Antique 40's French ceramic mantle clock. (By: volfghan)
    Thank you!!!
    Regards.
  1. Antique 1950's French SMI alarm clock.
    By Ticktocktime100 in forum Clock Repair
    Last Post: 01-02-2013, 07:37 AM
  2. Identifying Antique French Pendulum Mantle Clock.....
    By Bobdrfl in forum Clocks General.
    Last Post: 12-12-2012, 10:51 AM
  3. Need ID of french Slate mantle clock
    By Russell Dickson in forum Your Newest Clock Acquisition
    Last Post: 10-02-2012, 02:57 PM
  4. French Slate Mantle Clock Numbers Matching, and Signature on back of face
    By EStew0731 in forum Your Newest Clock Acquisition
    Last Post: 05-25-2012, 04:08 AM
  5. Large Porcelain French Faience Mantle Clock
    By carolinatrad in forum Clocks General.
    Last Post: 01-21-2011, 12:19 PM
