NOTICE Notice: This is an old thread. The last post was 1490 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 4 of 4
    Default Seth Thomas Legacy 1314A Mantel Clock Chimes Late
    Greetings,
    I have a 1982/83 Seth Thomas mantel clock that chimes late. The quarterly and hourly chimes are 2 minutes behind the actual time. The clock chimes at 2, 17, 32, and 47 minutes after the hour.
    This is a Seth Thomas catalog number 1314A (1314-001), Legacy model mantel clock and has the Franz Hermle, 2 jewel unadjusted 350-060 German movement.
    Is this something that I can fix or should I take the clock to a repair shop?
    Please let me know if you need anymore information.
    Thanks for your "time",
    Kevin
    Nov 2002
    38,864
    Default Re: Seth Thomas Legacy 1314A Mantel Clock Chimes Late (RE: KevinD)
    Hi, Kevin, welcome to the message board. The minute hand on your clock will have an adjustable bushing in the center. You will need a file tang or a square screwdriver that fits in the bushing so you can hold the bushing while moving the hand the small amount needed to reset it to match the movement. It's a trial and error adjustment. Grip the hand near it's bushing so you don't bend or break it.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    You can do this one.
    Take off the minute hand, hold the center part with pliers, or in a vice, then turn the hand back the distance of about 2 minutes. This may or may not take quite a bit of force.
    The best way to hold the center part is by placing it over a finely tapered square spindle, a small file handle will serve, or you can make a proper spindle using a small nail. Make the 4 flats with a bench grinder and finish with a file. The taper needs to be long, the longer the better.
    Registered user. Dick Feldman's Avatar
    Sep 2000
    Colorado, usa
    1,753
    Default Re: Seth Thomas Legacy 1314A Mantel Clock Chimes Late (RE: Willie X)
    I agree with what has been said.
    If the bushing moves too easily when you make the adjustment, it may slip again when the clock is set. If so, it might be necessary to replace the hand or to peen the bushing where it contacts the hand.
    D
  1. Seth Thomas Staunton Tambour Mantel Clock Question
    By finiteguy in forum Your Newest Clock Acquisition
    Last Post: 01-04-2012, 12:02 PM
  2. Replies: 33
    Last Post: 04-29-2011, 09:39 PM
  3. Chime Problems Seth Thomas Legacy 3W
    By Kacey in forum Clock Repair
    Last Post: 11-03-2009, 08:53 PM
  4. Seth Thomas Legacy-3w Mantel clock
    By clr526 in forum Clocks General.
    Last Post: 06-13-2009, 10:45 AM
  5. Seth Thomas Legacy 3W
    By 4everblonde in forum Clocks General.
    Last Post: 11-04-2006, 06:43 AM
