NOTICE Notice: This is an old thread. The last post was 4193 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
Thread: Gustav Becker
    Registered user.
    Oct 2003
    Kentucky
    695
    Default Gustav Becker
    I have 2 Gustav Becker movements,Could someone with knowledge of the Gustav Becker movements explain what R P37 on one and R P48 on the front plate means and also the #27 on both rear plates? They both look like twins.Thank you
    Don
    Registered user.
    Oct 2003
    Kentucky
    695
    Default Gustav Becker (By: Donald P Bellamy)
    Don
    Apr 2004
    Mesquite, TX
    938
    I'm a HUGE ( not physically ) fan of GB. Hope someone waxes knowledgeable and we'll both learn. I did my part. I put it back on toppa th' heap.
    Hi Don,
    I have a two train GB marked P64. From the flex point if the suspension spring to the center of the pendulum bob measures 25.5 inches or slightly more than 64cm. I suspect that the P37 and P48 would be the pendulum lengths for your clocks.
    Joe
    Registered user.
    Oct 2003
    Kentucky
    695
    Those measurements for the P48 are 9.5" and 7" for the P37, so It may be safe to say those #'s are pendulum length. Thank you.
    Don
  6. #6
    Apr 2004
    Mesquite, TX
    938
    Yeah DONALD: That's what I was gonna say. ( yeah - RIGHT! )
  1. Need help Gustav Becker clock information
    By joeZy in forum Clocks General.
    Last Post: 09-21-2006, 07:21 AM
  2. Gustav Becker double weight
    By vienna_sucker in forum Clocks General.
    Last Post: 08-26-2006, 08:06 AM
  3. Gustav Becker Grand Sonerie
    By CG in forum Clocks General.
    Last Post: 04-10-2005, 08:11 AM
  4. Gustav Becker
    By Mike306p/Ansoniaman in forum Clocks General.
    Last Post: 11-19-2002, 03:30 AM
