NOTICE Notice: This is an old thread. The last post was 1553 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 3 of 3
    Default cuckoo clock hand replacement
    In replacing cuckoo clock hands, the minute hand has a brass insert with square key. Should this be press fit only or should the brass insert be glued in?
    It does not fit tightly by itself but when the post nut is screwed on then it seems tight.
    Default Re: cuckoo clock hand replacement (By: CGC)
    Quote Originally Posted by CGC View Post
    That's how it's supposed to fit. That way, if your minute hand doesn't match the strike time, you can turn it a little on that shoulder and tighten it again with the nut.
    Default Re: cuckoo clock hand replacement (By: shutterbug)
    There should be a flat brass flat washer between the hand and the nut. This is often lost. It is just slightly larger than the nut.
  1. Cuckoo Clock Hand Removal ???
    By malshirl in forum Clock Repair
    Last Post: 12-20-2008, 07:20 PM
  2. Securing cuckoo clock hands
    By ClocksCollector in forum Clock Repair
    Last Post: 11-18-2008, 08:34 PM
  3. Cuckoo Clock hand spacers
    By FredWJensen in forum Clock Repair
    Last Post: 11-06-2008, 07:56 AM
  4. Bone Cuckoo Clock Hands
    By glr1109 in forum Clock Repair
    Last Post: 10-29-2007, 09:34 PM
  5. Cuckoo Clock Hands.
    By Oldtime in forum Clock Repair
    Last Post: 05-13-2006, 08:27 PM
