Goal: $300, Received: $185.00 (62%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 1577 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 7 of 7
    Registered user. ClockFanatic's Avatar
    Dec 2011
    Birmingham, United Kingdom
    216
    Default A Reproduction Horolovar Rotary Pendulum Clock
    Hello everyone,
    Just pick up one Horolovar Rotary Clock. It's reproduction but I think not Chinese copy because it has Made in Germany on the dial. I don't know the maker as no stamp on the back etc. I don't know if there somewhere on the movement plate (behind). On the top plate just saying "BRIGGS ROTARY PENDULUM CLOCK, US PATENT AUG 1855, HOROLOVAR REPRODUCTION". It's in working order but because of the line too long, I need to put a paper to lift the ball. Will adjust it later. The dome is in very good condition and high quality (very thick).
ID:	156011Click image for larger version.
ID:	156012Click image for larger version.
ID:	156013Click image for larger version.
    Can't stop thinking..even during sleeping..
    Apr 2004
    Mesquite, TX
    938
    Default Re: A Reproduction Horolovar Rotary Pendulum Clock (By: ClockFanatic)
    Repro or not it's a VERY nice ack. Congrats; Enjoy!
    Dec 2011
    216
    Default Re: A Reproduction Horolovar Rotary Pendulum Clock (By: Scottie-TX)
    Quote Originally Posted by Scottie-TX View Post
    Thanks Scottie-TX.. Yes it's very nice. I'm glad won that for £59 (including comission). I don't know whether considered expensive or not for reproduction. but sure I like to watch it. I can't afford to own French Mystery Conical Pendulum. Unless got lucky enough..:cyclops:
    Registered User Burkhard Rasch's Avatar
    Jun 2007
    Twistringen
    3,933
    they usualy go much higher,so Congrats!I drive mine with a piece of surgical thread,works fine.They were ordered from different german makers in batches,mine bears the logo of Mathias Bšuerle.After TLC they keep to ca.3min per week,not too bad for a novelty clock.
    Burkhard
    Gigni de nihilo nihil,et nihil in nihilum posse reverti
    (Persius)
    Dec 2011
    216
    Default Re: A Reproduction Horolovar Rotary Pendulum Clock (By: Burkhard Rasch)
    I have just open the box (after more than one month in the container). Because of the line to long, I took off the line and refitted. Now the problem is, ball swing too strong and over than the needle and touching the glass. Anyone can help me to make the ball keep swinging along the needle? Thank you.
  6. #6
    Dec 2011
    216
    The needle (or rod) is straight. Should I bent the road to be like a little bit 'J' hook? Previously it's working fine with straight rod.
  7. #7
    Jun 2007
    Twistringen
    3,933
    definitely NOPE.It is designed to work with a staight pin,and it did work with it,so the fault must be looked for somewhere else.Like in a recoil escapement these Briggs reproductions depend heavily on an even transmission of power.Iīd propose a full service incl. the mainspring which will probably resolve the problem.HTH
    Burkhard
    (Persius)
  1. Rotary pendulum clocks
    By Shayne in forum Clocks General.
    Last Post: 05-29-2012, 12:58 PM
  2. My new flying pendulum clock reproduction
    By cazboy in forum Your Newest Clock Acquisition
    Last Post: 05-08-2010, 07:28 PM
  3. Kroeber Rotary Conical Pendulum Clock
    By in forum Clocks General.
    Last Post: 04-06-2007, 12:12 PM
  4. Replies: 3
    Last Post: 05-29-2004, 07:00 AM
  5. Horolovar Flying Pendulum Clock
    By timelyrestorations in forum Clocks General.
    Last Post: 05-17-2003, 10:07 AM
