Goal: $300, Received: $40.00 (13%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 1542 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 1 of 2 12 LastLast
Results 1 to 15 of 20
    Default Verge Fusee 1776 pocket watch
    Hello, this is my pocket watch; Hallmarks say that it was made in year 1776 in London.
    I'm not an expert and i would know wath do you think about it.
    Do you know who is H. dalrymple? Thanks for your answers.
    Attached Thumbnails Attached Thumbnails hallmark.jpg   movt.jpg   case.jpg   face.jpg   face2.jpg
    Registered User gmorse's Avatar
    Jan 2011
    6,440
    Blog Entries
    Default Re: Verge Fusee 1776 pocket watch
    Hi and welcome to the Forum.
    A nice clean English verge pair-case. I'm afraid I can't find a Dalrymple in London, but that's just one reference, so I expect others may fill this in; if not, it may just be the retailer. The cases were made by James Richards at 1 Bridgewater Square, registered at this address in September 1774. Some repairs to the inner case where the pendant attaches. Not sure about the 'skipped' coil on the fusee? Everything looks completely right for 1776.
    Hello gmorse, and many thanks for your welcome .
    I' m sorry for my english (I am writing from Italy). What do you mean for "skipped coil on the fusee"?
    This pocket watch is in good working condition.... I show other pictures, for understand better. I hope that someone can help me to know history of my pocket watch. I bought it one month ago and is important for me explain to my wife that i spent my money very well
    Thanks and regards!
ID:	154911Click image for larger version.
    Jan 2011
    6,440
    Blog Entries
    Hi,
    In the last picture in your first post, the chain is sitting in the lowest two grooves in the fusee, (the grooved conical piece), and then there's an empty groove before the final turn of the chain. The chain does seem to be attached and unbroken, so I assume that it has skipped a groove on the other side of the fusee that we can't see. This isn't a problem if the chain is unbroken, as it can be put back in the right place after it's removed for servicing.
    I should not run the watch in this condition, but have it serviced if you can find someone who understands these watches properly.
    The watch paper is a nice piece of history to keep with the watch, showing a repairer in Chesterfield from earlier times, but be careful as they are fragile. There may be others underneath this one.
    Now I understand, I will follow your advice. Thanks for your answers,
    best regards,
    Alessio
  6. #6
    Quote Originally Posted by gmorse View Post
    I found in internet an interesting story regarding Mr James Richards at this link:
    http://www.oldbaileyonline.org/print...iv=t17690222-9
  7. #7
    Jan 2011
    6,440
    Blog Entries
    Hi,
    That's fascinating, and not, I think, that unusual. There were clearly very good reasons why masters were restricted in the number of apprentices they could take on at any one time! I wonder what happened to the dishonest apprentice? Sentences were pretty harsh at that time.
  8. #8
    Registered user.
    Jan 2012
    torino italy
    951
    hello
    only a small problem due to the non-alignment of the chain on the barrel
    unwind and alignment again
    regards enrico
  9. #9
    Registered user. Les harland's Avatar
    Apr 2008
    Hertfordshire England
    592
    Is the Hallmark definitely 1776?
    It looks more like 1816 to me
  10. #10
    Quote Originally Posted by eri231 View Post
    hello
    regards enrico
    Hello! thanks for your advice!
    Do you know a repairer near Torino for verge pocket-watch like this one? I would show him the little issue of chain-alignement.
    I'm writing from a location near Mondovž....
    Alessio
  11. #11
    Registered user.
    Jan 2012
    torino italy
    951
    the two hallmarks are very similar
    no doubt about the date
    regards enrico
  12. #12
    Quote Originally Posted by Les harland View Post
    Hello,
    i'm checking on this site http://www.925-1000.com/dlc_london.html and seems that the "a" letter to identify the year 1816 has a small pointer at the base, what do you think?
    thanks for your answer,
    Alessio
  13. #13
    Registered user.
    Jan 2012
    torino italy
    951
    hello
    i'm not so far (torino)
    sorry but I do not know watch repairers
    but you can look at a watch forum of turin
    regard enrico
  14. #14
    Registered user. Squite's Avatar
    Jun 2012
    Seattle, WA, USA
    2,274
    Quote Originally Posted by skuhravy View Post
    Hello,
    Alessio
    I don't see really any difference between the two marks in question except for the fields in which they are stamped. Personally I feel it more closely resembles the field of the 1816 mark, with knocked corners, than the 1776 mark, which is more rounded (larger corners look to be knocked off). The tail of the 'a' is obscured on the stamp itself, so I feel it could really be either of them based on that consideration. I have heard that there are intricacies that the charts on that website do not show, however. So I'm not sure that it's the best source.
    You're probably better off to use it as a guide, along with the pillar shapes, the engraving on the movement, the case maker's initials, and even the case paper information to some extent. They are all pieces of the story this watch has to tell.
  15. #15
    hello
    regard enrico
    Doesn't matter,
    thanks for the picture with explanation to align the chain. but i'm not sure to try to register it...
    Alessio
  1. Henry O. Stauffer 1776 pocket watch. I just had to share this one with all of you.
    By Larry Krayer in forum European & Other Pocket Watches
    Last Post: 12-06-2012, 10:10 PM
  2. Bullingford fusee drive pocket watch
    By dogma79 in forum European & Other Pocket Watches
    Last Post: 04-05-2011, 06:25 PM
  3. Identify Early Pocket Watch verge fusee painted dial
    By smellyal in forum European & Other Pocket Watches
    Last Post: 02-01-2010, 05:18 PM
  4. fusee Alarm Pocket Watch?
    By vandd in forum European & Other Pocket Watches
    Last Post: 01-27-2009, 02:52 PM
  5. Doubled cased English Fusee Verge pocket watch
    By tonal28 in forum European & Other Pocket Watches
    Last Post: 01-05-2008, 09:28 PM
