Results 1 to 11 of 11
    Default Help Identifying Haller Mantel Clock
    Hi, I recently purchased this Haller Clock and was wondering if anyone could tell me more about it.
    On the back door inside there isa slip of paper that gives lengthy explanation about how this is fitted with one of the finest movements, and how to use it. Inside on the bottom is a semi circle above the word Haller, and below that the word foreign, and below that is a six digit what I am guessing is a serial number, 138299.
    To the right is 12cm over 190:66
    Now on the top of the bacj movement is scratched 10w into the metal, and where the bars that mvoe to make the sounds is scratched in 12/10/54 RA. These two were not done by a machine but maybe by a clock repair person?
    On the bottom of the case etched intot he wood is the number 103, but I am guessing this isn't as relevant.
    Any help is appreciated
    Bill
    Registered User soaringjoy's Avatar
    Feb 2009
    7,240
    Default Re: Help Identifying Haller Mantel Clock (By: weppler1978)
    Bill, welcome to the board.
    I could tell you a lot about your (unseen) clock, because my crystal ball is
    working and running fine at the time. Alas, assumptions, nothing more.
    So, please go ahead and post some pictures of your clock and movement.
    Jurgen "tempus nostrum"
    Default Re: Help Identifying Haller Mantel Clock (By: soaringjoy)
    Pics attachedClick image for larger version.
ID:	151087Click image for larger version.
ID:	151088Click image for larger version.
ID:	151089Click image for larger version.
ID:	151090Click image for larger version.
ID:	151091Click image for larger version.
ID:	151092Click image for larger version.
ID:	151093Click image for larger version.
    Feb 2009
    7,240
    OK, that's something we can work with, thanks for posting.
    Your mantel clock was made by Thomas Ernst Haller AG, Schwenningen.
    It has a three train Westminster chimes movement and the scratched-in figures
    are indeed clock repairers marks. The 12cm is the pendulum length in centimeters
    measured from the pallet arbor to pendulum tip. I'm not sure about the other numbers;
    perhaps a wheel tooth count ratio.
    The clock was made for export to the UK, which is verified by the term "foreign", a
    requirement of a 1926 supplement to the British Merchandise Marks Act.
    That tells us, that the clock was not made before that year, and I would believe it is
    early 1930s, considering the hands nut.
    The dial was silvered originally. The case front is a "medium" oak, which has turned darker
    through the years. A nice burlwood finish on the back (!) side.
    There has been replacement work done on the chime rods, but I can't say, which have
    been switched.
    The clipping is from a 1931 Th. E. Haller ad.
    Wow, thanks.
    Can you tell me how many days it is?
    That was more information then I hoped for, thank you so much, you're the man!
  6. #6
    It's an eight day clock. Timesavers sells a chime rod set that sounds identical to some of these Haller's rods.
    The clock is probably very late 1920's or 1930's as suggested.
    "Experience, Education, & Enjoyment." - Justin A. Olson
  7. #7
    May 2012
    Southern Highlands of NSW, Australia
    569
    Default Re: Help Identifying Haller Mantel Clock (By: chimeclockfan)
    If the 12cm is the pendulum length (which I am certain is correct) then I am pretty sure that the 190 will be the beats per minute. I am not sure about the 66.
    Cheers
    Walesey
  8. #8
    Default Re: Help Identifying Haller Mantel Clock (By: Walesey)
    I too have a Haller clock with similar markings i.e.
    Haller, foreign, 12CM, 190,66. It only has the hour & half hours chime. It was presented to my parents as a wedding present in 1933. It has problems with both the main & Chime springs. One is broken at the winder end and the other slips at outside end after only a few turns on the winding key. Other than that is in remarkable good condition.
    My problem is to remove the springs SAFELY from the drums that contain them. It would appear that the out side (Beginning?) of both springs is riveted onto the drum.
    Any help would be much appreciated.
    Johnande
  9. #9
    Default Re: Help Identifying Haller Mantel Clock (By: Johnande)
    Welcome to the board.
    You might have done better by posting your request in Clocks Repair section, rather than joining it to a thread which is more than four years old...........however, if you do a search (search box at the top of the page) you will find a great deal of information about removing springs safely.
    You springs are likely attached to a stud on the wall of the drum, they will not be rivetted onto it. However, if the springs broke, there may have been other damage done to the movements and I would suggest that the clock is fully cleaned and serviced, not just the springs replaced, as it seems not to have run for quite some considerable time.
    Do you have any experience of clock repair? Plenty of people will be happy to help you if you need it.
    JTD
  10. #10
    Default Re: Help Identifying Haller Mantel Clock (By: JTD)
    Thanks for the reply and sorry for placing my problem in the wrong spot.
    I am purely amateur at clock repair but have had success in the past. The movement has been cleaned. The problem is, although I have made a spring removing tool which works well on none captive springs. When contained in a drum, they need to be "wound up" to get the out. As both cannot be "wound up" I cannot extract them into the tool to let them down! Safely.
    Johnande
  11. #11
    Administrator Bill Stuntz's Avatar
    Apr 2012
    Columbus. OH
    3,457
    Blog Entries
    Since they won't wind up, they're already "let down" into the barrels. You should be able to safely remove the barrels. It IS possible to manually remove the springs by pulling out the inner coils. BE SURE TO WEAR GLOVES & SAFETY GOGGLES in case they get out of control. Repairing the clock is NOT worth a trip to the hospital. Springs can be dangerous if they're handled carelessly.
    And as JTD said, arbors/pivots/teeth may have been bent or broken when the springs let go. It might be better to have it professionally repaired, but since you've "had success in the past" I assume you've successfully disassembled/reassembled at least one movement before tackling this one. Be sure to take lots of pictures at each stage as you disassemble it.
  1. Help identify my mantel clock
    By Yellow11 in forum Clocks General.
    Last Post: 03-14-2012, 06:17 AM
  2. Please Help Identify/Date Mantel Clock
    By stevedeb in forum Clocks General.
    Last Post: 11-18-2011, 01:51 PM
  3. Help to Identify a Mantel Clock - SE on dial
    By joedawolf in forum Clocks General.
    Last Post: 09-01-2009, 08:32 AM
  4. Help please identifying old mantel clock
    By tiktok in forum Clocks General.
    Last Post: 03-23-2009, 02:34 PM
  5. Help identifying Waterbury Mantel Clock
    By gungi21 in forum Clocks General.
    Last Post: 03-23-2009, 12:37 PM
