Goal: $300, Received: $280.00 (94%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 4581 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 7 of 7
    Michael Vala
    Guest
    Default Cuckoo with two cuckoo birds-1930s Schmeckenbecher
    I have a very old (guessing 1920s-30s) Schmeckenbecher Cuckoo clock with 2 cuckoo birds, 3 bellows, 3 chains, rather heavy weights (I think 875 gram, possibly heavier). Its a fairly large clock and a very heavy brass movement. I'm just getting into it now to see if I can get it to run. Does anyone know this clock, and how the cuckoos operate. It also has two strike hammers/gongs.
    Michael Vala
    Guest
    Default Cuckoo with two cuckoo birds-1930s Schmeckenbecher (By: Michael Vala)
    Hi Michael,
    This is called a quail and cuckoo clock. Can you post pictures of it here?
    Andy
    <span class="ev_code_RED">Try to make the Message Board a fun place to visit again! </span>
    So many clocks, so little time.
    The International 400 Day Clock Chapter 168, Global Horology Chapter 192.
    Michael Vala
    Guest
    Here are a couple of photos. Thanks for the reply--I have heard of those cuckoos and never knew that's what they were. Are these kind of rare?
    Michael Vala
    Guest
    Here is photo of the front--traditional carvings--a rather large clock. Still do not know how it cuckoos. When and how does second bird cuckoo. I will be removing movement to check it out.
  6. #6
    Michael,
    Your's does look like an older one, 1940s or earlier. They do still make them today, but the quail and cuckoo is a lot higher price when new than just the cuckoo, the reason you don't see many of them.
    The quail makes a single note, like "he-he-he" every quarter hour. It does that once for every quarter, so 4 sets on the hour. Usually they cuckoo once on the half hour after the quail has sounded, and they count the hour. So they are very noisy. Twelve o'clock has a gong and He-he-he 4 times, then a gong with cuckoo calls 12 times! That is 52 seperate sounds just at 12! You don't want to run one of these in your bedroom!
    Andy
  7. #7
    Michael Vala
    Guest
    I got the movement out and not only does it work great, I figured out the sequence. It also has two chimes and hammers--why I'm not sure--they are the same sized gongs and similar sound--seems pointless. But, whoever first developed this clock was probably a little cuckoo! Thanks for the info
  1. Beha Shelf Cuckoo with Exposed Feathered Bird
    By BLACK FOREST CLOCKS in forum Your Newest Clock Acquisition
    Last Post: 08-26-2012, 08:51 AM
  2. Cuckoos with propellers
    By RJSoftware in forum Clocks General.
    Last Post: 08-20-2006, 12:03 AM
  3. Cuckoo with dancing figures
    By Frank Manning in forum Clock Repair
    Last Post: 12-13-2005, 07:23 AM
  4. Need help with British Cuckoo Clock
    By Joe Gensheimer in forum Clocks General.
    Last Post: 11-01-2005, 11:51 AM
  5. A vintage 30 hour cuckoo with really heavy weights
    By Michael Vala in forum Clocks General.
    Last Post: 09-25-2004, 04:21 PM
Members who have read this thread: 0
There are no members to list at the moment.
