Goal: $300, Received: $335.00 (112%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 1593 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 7 of 7
    Registered User Ingo Werner's Avatar
    Mar 2010
    Minneapolis
    141
    Default Marion Kay Coin Clock (1964 Last Silver Coins) - Replacement Movement
    A friend brought me his Marion Key Coin Clock because the original movement decided to retire. I am searching for a replacement fit-up movement, but I would like to re-use the original hands in order to preserve the authentic look of the clock. Can anyone advise of a fitting movement?
    Thank you for your help and input!
    -Ingo
ID:	148694Click image for larger version.
    Default Re: Marion Kay Coin Clock (1964 Last Silver Coins) - Replacement Movement (By: Ingo Werner)
    Looks like any quartz movement will work. You will need to match the movement to the dial thickness. The hands look like common quartz types. Try Klockit. Bob.
    Mar 2010
    Minneapolis
    141
    Default Re: Marion Kay Coin Clock (1964 Last Silver Coins) - Replacement Movement (By: Bob Fisher)
    Thank you, Bob.
    -Ingo
    I can't see for sure, but I think your movement might be a self wind. If that's the case, you won't find a replacement easily ... but as Bob said, a quartz should fit just fine. You may have to modify the hands to fit, but that's fairly easy to do.
    Mar 2010
    Minneapolis
    141
    Default Re: Marion Kay Coin Clock (1964 Last Silver Coins) - Replacement Movement (By: shutterbug)
    Thank you.
    -Ingo
  6. #6
    A "C" cell quartz will do it. It will probably be slightly smaller than the old one but will look very much like the old one. A "AA" movement will look to small and out of place.
  7. #7
    Mar 2010
    Minneapolis
    141
    Default Re: Marion Kay Coin Clock (1964 Last Silver Coins) - Replacement Movement (By: Willie X)
    Thank you
    -Ingo
  1. Silver coin cases
    By dweiss17 in forum American Pocket Watches
    Last Post: 11-14-2010, 07:58 PM
  2. Ormolu "Death Clock" on last night's episode of Pawn Stars
    By Spaceman Spiff in forum Clocks General.
    Last Post: 09-22-2009, 04:30 PM
  3. Arrow Coin Clocks.......
    By Netdad in forum Electric Horology
    Last Post: 02-02-2006, 08:39 AM
  4. Replacing movement in old slave clock
    By Hesperian in forum Clock Repair
    Last Post: 08-26-2005, 07:25 AM
  5. Clock guy needs help with Omega movement.
    By Doug Campbell in forum Wrist Watches
    Last Post: 10-07-2004, 09:33 AM
