Goal: $300, Received: $275.00 (92%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 1781 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 3 of 3
    Default Grandmother vs Grandfather clock
    Hi, what is the difference between a grandmother clock and a grandfather clock? Thank you, John
    Nov 2002
    39,829
    Default Re: Grandmother vs Grandfather clock (By: SouthernYankee)
    Usually it's a height thing. A grandfather will be over 6 feet tall, and a grandmother, around 6 feet or smaller. Then you find granddaughter clocks at around 4 feet tall.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Default Re: Grandmother vs Grandfather clock (By: harold bain)
    In the UK, small spring driven floor clocks, best described as mantel clocks on pedestals, are known as Grandmother clocks. There are no real standards, but Harold's posting is largely correct for the US terms.
    "A good gong sells the clock!" - Justin A. Olson
  1. Schatz grandmother / grandfather clock.
    By SouthernYankee in forum Clocks General.
    Last Post: 08-20-2012, 03:26 PM
  2. How to identify an American vs English Grandfather clock movement
    By Weight Driven in forum Clocks General.
    Last Post: 10-28-2006, 05:55 PM
  3. Previous Info on Grandfather Clock ID Request.
    By Paul Lopez in forum Clocks General.
    Last Post: 09-19-2006, 02:11 AM
  4. Grandfather clock stopping
    By Steve G in forum Clock Repair
    Last Post: 01-17-2006, 01:36 PM
  5. Grandfather Clock
    By apjarvis in forum Clock Repair
    Last Post: 11-21-2004, 06:12 AM
