NOTICE Notice: This is an old thread. The last post was 1569 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 15 of 15
Thread: Mauthe Movement
    Jan 2011
    Pottageville Ontario Canada
    1,993
    Default Mauthe Movement
    Just had a friend bring one in. Movement looks exactly like a Hermle. Does anyone know if Hermle made movements for Mauthe? If so, I was thinking of swapping in a spare Hermle time train barrel that I have for the Mauthe one that has a bad mainspring. That is if the teeth count is the same.
    Default Re: Mauthe Movement (RE: hookster)
    I've seen them in several kinds of clocks, but they always had the Hermle numbers stamped on the plates, and the other pendulum info. as well. Often they have another name instead of Hermle, but I haven't found one yet that was void of the movement numbers.
    Nov 2002
    38,618
    Default Re: Mauthe Movement (RE: shutterbug)
    Quote Originally Posted by shutterbug View Post
    I just overhauled a 1930's vintage Hermle that only had FHS stamped on the plates. No movement numbers.
    Hookster, I wouldn't expect them to be the same. If both barrels are good, why not just swap the springs? This will give you something easy to measure for comparison (the springs).
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Jan 2011
    1,993
    Default Re: Mauthe Movement (RE: harold bain)
    You are right Harold. Why be lazy. Swapping the spring is obviously no big deal. The old spring in the Mauthe is not broken, just tired out, so no damage appears evident and the movement otherwise looks pretty clean, with little or no bushing wear. Now, back to searching for the missing parts for my newly acquired Schatz cuckoo movement.
    Quote Originally Posted by hookster View Post
    Hook,
    The sure did.
    They made them for several famous movement makers, when the old companies were trying to cut corners to keep their ship afloat.
    They (Hermle) even stamped their movements for several clock supply companies, and also clock kit companies.
  6. #6
    Registered User soaringjoy's Avatar
    Feb 2009
    7,240
    Default Re: Mauthe Movement (RE: Willie X)
    Quote Originally Posted by Willie X View Post
    Hook,
    The sure did.
    Yupp.
    Jurgen "tempus nostrum"
  7. #7
    Jan 2011
    1,993
    Default Re: Mauthe Movement (RE: soaringjoy)
    OK I have it all apart. Only the T1 wheel needs to be bushed. I know that we have had this debate before, but is it best to leave the center cam on its arbor or remove it to have a look see? I find reassembly easier with it off. Also, the mainsprings look a little gummy so they will need to come out to be cleaned/oiled, and maybe the time one replaced. Reminder, it is very similar to a 3 train Hermle.
  8. #8
    I'll modify my former "no" to a "maybe" depending on the condition of the rear pivot. If it needs to be dressed, then 'yes'. If not .... 'no'.
  9. #9
    The Mauthe units made by Hermle were usually stamped with a '502' on the rear plate.
  10. #10
    Jan 2011
    1,993
    Default Re: Mauthe Movement (RE: MARK A. BUTTERWORTH)
    Yepp Mark, you ate bang on correct. Marked 502.
  11. #11
    Feb 2009
    7,240
    For the records, if the movement is post 1975, it has nothing to do with
    the Friedrich Mauthe Schwenningen Co., except for the use of the name
    for marketing.
    That "502" rang a bell...
  12. #12
    Jan 2011
    1,993
    All back together and running fine, except that I am only getting a maximum of 1.5 inches of pendulum swing, regardless of how I adjust the verge/crutch bridge or the beat. It is a 35 cm pendulum length. Any thoughts? Is that amount of swing typical?
  13. #13
    It could be fine. How much over-swing do you have. That's a more important barometer of health
  14. #14
    Jan 2011
    1,993
    Over swing seems OK.
  15. #15
    Then you should be good
  1. Friedrich Mauthe Movement Question...
    By Chris Pickell in forum Clock Repair
    Last Post: 03-09-2011, 04:16 PM
  2. Mauthe Movement
    By ticktock in forum Clock Repair
    Last Post: 09-20-2010, 06:06 PM
  3. "FMS" Mauthe Movement
    By marine6072 in forum Clocks General.
    Last Post: 11-12-2009, 07:29 AM
  4. Date This Mauthe Movement?
    By bangster in forum Clocks General.
    Last Post: 08-04-2007, 07:01 PM
  5. dating a Mauthe movement
    By Dana Armour in forum Clocks General.
    Last Post: 01-16-2007, 01:10 AM
