Goal: $300, Received: $360.00 (120%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 1681 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 2 of 2
    Default Early Swiss National Park Stopwatch with Excelsior "J" movement
    I recently purchased a Swiss made stopwatch with National Park on the dial. I did some reading on this brand and know that it was first used in 1891 by Gallet. I also know that these watches were used to time cars and horses in the old days. I think the movement is an early Excelsior movement--part of the movement is shaped like a "J," for Jeanneret & Freres, who patented the movement. While browsing the internet, I came across a picture of the movement that was patented--this one is just like it. Later ones have a small compartment holding spare parts, which this one does not have.
    I was wondering if this watch could possibly be one of the earliest or even first made? The only writing visible on the movement is the number 3364 with a cross (Swiss?). Others I have seen have the parts compartment and two numbers on the movement--the other being the patent number(?)--388992 or DRP 388992. I don't know if it helps or not, but the dust cover is inscribed with the number 191311, with no name. The case, I believe, is nickel.
    Any information you could give me on this watch would be greatly appreciated. Thanks so much for your time.
    Registered User doug sinclair's Avatar
    Aug 2000
    Calgary, Alberta
    14,368
    Blog Entries
    Default Re: Early Swiss National Park Stopwatch with Excelsior "J" movement (By: dyb225)
    I have heard of Excelsior Park, but never National Park. I have never seen a dial marked Excelsior Park. Given all of this, I might understand a dial marked National, with an Excelsior Park made movement in it. Perhaps someone else can shed some light on this.
  1. Help with Seth Thomas A206-002 movement.
    By Lloyd M in forum Clock Repair
    Last Post: 02-16-2012, 05:50 PM
  2. National Convention / Fascinated With Time?
    By Gene Klodzen in forum NAWCC NEWS.
    Last Post: 04-21-2008, 04:47 PM
  3. Replies: 20
    Last Post: 02-24-2007, 05:09 PM
  4. Need help with small Waterbury balance wheel movement
    By steve45jm in forum Clock Repair
    Last Post: 10-26-2006, 02:22 AM
  5. Replies: 19
    Last Post: 10-17-2005, 07:32 AM
