NOTICE Notice: This is an old thread. The last post was 1626 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 9 of 9
    Default Seth Thomas no 2 regulator wall clock, identification help
    Hello.
    I will post pictures as soon as I can, one of my children has my camera AGAIN,
    I have just purchased this clock.
    The case is Mahogany and 36.5 inches total length
    Single weight
    The dial has damage, but livable.
    Unlike everthing I can find on the web, the markings on the dial is just, ST (in script) in the diamond and in the circle,under this USA.
    There appears to be a stencilled number on the back well faded but I think it is 3981B.
    I know it is not much to go on without pictures, but hopefully I can post these soon.
    Any help would be great.
    How do I get to the movement, the pendulum has been taken off and I am finding it difficult to put it back on.
    Many thanks Peter.
    Default Re: Seth Thomas no 2 regulator wall clock, identification help (RE: peter hurst)
    As you said, not much help without photos. Open the bezel (top glass over dial). To remove the dial first remove the hands. Then remove the seconds "bit" (hand) by grasping it near the hub and pulling straight out. There are usually 6 or more screws around the edge of the dial and a couple near the center which fasten to the wooden support underneath. That should be it.
    If the cable was not secured it may be coiled around the winding arbor or otherwise balled up. You will have to carefully straighten it out and then hang the weight to keep tension on it.
    Please post photos as soon as you can.
    Best,
    Richard T.
    Nov 2002
    38,601
    Hi Peter. If you are correct about the stamp on the back, your clock was made in 1893. Taking the dial off: start by removing the hands, then remove the screws around the dial. This will make putting the pendulum back on much easier.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Registered User inbeat's Avatar
    Nov 2000
    Phoenix, AZ
    1,846
    Default Re: Seth Thomas no 2 regulator wall clock, identification help (RE: harold bain)
    From your description and from the stamp your indicated on the back, you have a #2 made with a Seth Thomas #61 movement. This movement is rectangle shaped as opposed to the trapazoid movements in the later #2's. If your dial is original to the clock and not repainted, it should be roman numeral. Hard to say much else without pictures.
    Default Seth thomas pictures for identication help (RE: peter hurst)
    Hello,
    Here are the pictures as promised.
    Mahogany case, 36.5 inches.Click image for larger version.
ID:	141027Click image for larger version.
ID:	141028Click image for larger version.
ID:	141029Click image for larger version.
ID:	141030Click image for larger version.
    2 clock repair marks on pendulum bob. 1906 and 1913
    Transfer number on rear of case 3981b
    no marks on movement.
    Your comments please.
    Thanks peter.
  6. #6
    Default Re: Seth thomas pictures for identication help (RE: peter hurst)
    I see a Seth Thomas # 2 made in March of 1898. Are there other questions here?
  7. #7
    Default Re: Seth Thomas no 2 regulator wall clock, identification help (RE: Socaljet)
    Quote Originally Posted by Socaljet View Post
    Looks like Fe. 1893. There was an earlier thread. I have merged them into one.
    “If one tells the truth, one is sure, sooner or later, to be found out.” - Oscar Wilde
  8. #8
    Default Re: Seth Thomas no 2 regulator wall clock, identification help (RE: Steven Thornberry)
    Thankyou all very much, I am very pleased with the result, as I thought it may be much later.
    Once again Thanks, Peter.
    I also bought another clock with this one and I am sure you will find it very interesting.I will post pictures soon.
  9. #9
    Registered user. Russell Dickson's Avatar
    Dec 2011
    New York
    460
    Quote Originally Posted by peter hurst View Post
    Hello,
    Thanks peter.
    Looks like a #2 Regulator, you are a lucky man, they are fine clocks and valuable too
  1. Seth Thomas No.19 Wall Regulator
    By ClockMogul in forum Clocks General.
    Last Post: 10-25-2011, 10:39 AM
  2. Seth Thomas No. 3 Wall Clock Case Pieces Needed
    By clockdoc01 in forum Clock Case Restoration and Repair.
    Last Post: 05-30-2011, 09:39 PM
  3. Help. Seth Thomas 6foot tall wall clock. what is it??
    By wheelgun357 in forum Clocks General.
    Last Post: 05-24-2011, 01:31 PM
  4. Replies: 14
    Last Post: 07-24-2005, 01:21 AM
  5. Barrister style Seth Thomas #2 Regulator Wall Clock
    By Bill Kendrick in forum Clocks General.
    Last Post: 12-21-2003, 11:50 PM
