NOTICE Notice: This is an old thread. The last post was 1705 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 5 of 5
    Default Junghans ATO mantel clock
    Hello,
    I have a Junghans ATO mantel clock , age unknown, but from what I have read, probably from the mid-fifties. It is 1.5V cell-powered, and not transistorised. A link to what it looks likes is here: http://www.clock-museum.co.uk/c186.htm
    I am looking for directions to regulate it.
    I already know that the pendulum needs to be screwed clock-wise or anti-clockwise to adjust it, and if the bob is let down, it runs slower.
    Any advice?
    Thanks!
    Registered user.
    Nov 2010
    Hampshire, UK
    100
    Default Re: Junghans ATO mantel clock (By: Gene)
    You seem to have found the answer already. If that doesn't work, then the incorrect suspension spring may have been fitted. The Kundo and Junghans springs are of different stiffness.
    Dennis.
    Default Re: Junghans ATO mantel clock (By: dennishoy)
    New to the forum. Decided I didn't have enough hobbies to throw away money my wife could spend, and got into clocks. My first project is this lovely Junghans mantel clock, or at least that's what my buddy Google said. Looking for guidance on where to start? I have the dome. I am guessing something is missing between the pendulum and where it attaches to clock body?Click image for larger version.
Name:	2012-10-24 21.59.57.jpg
    Nov 2002
    39,627
    Default Re: Junghans ATO mantel clock (By: jpparker19)
    Hi, Jp, welcome to the message board. Your clock is missing the suspension spring (or at least the bottom half of it) to suspend the pendulum. Timesavers part # 12011 should fix it.
    www.timesavers.com
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
    Apr 2002
    20,074
    Blog Entries
    Default Re: Junghans ATO mantel clock (By: harold bain)
    Sometimes the notch where the spring goes in needs to be opened a bit, a very tight fit, i broke a spring once when putting my first one in. Congrats to a fun hobby, i hope it works well when you do the repair needed.
  1. 1962 Junghans ATO Electronic Clock
    By eskmill in forum Electric Horology
    Last Post: 09-13-2012, 06:18 PM
  2. junghans ato electic clock
    By eemoore in forum Electric Horology
    Last Post: 04-26-2008, 03:34 PM
  3. Junghans ATO Battery Clock info
    By gmorglj in forum Clocks General.
    Last Post: 11-14-2005, 10:36 AM
  4. Early? Junghans ATO electric clock
    By Weight Driven in forum Electric Horology
    Last Post: 07-07-2005, 01:09 AM
  5. Junghans ATO Electronic Clock Schematic Needed
    By mlschlot in forum Electric Horology
    Last Post: 01-19-2005, 05:42 AM
