Goal: $300, Received: $260.00 (87%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 1635 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 9 of 9
    Default Ingraham Mantle Clock - Movement # 27
    Hello NAWCC,
    I have been asked by my mother-in-law to put her Ingraham 1833 Mantle Clock into good running order; to that end I am trying to determine the size of the bob that I need to replace, both size & weight, as I cannot do much else until I can see if it will run but the old bob was broken. I realize I could check the size & weigt of the old bob but I'm not sure at this point if that was even the correct bob for the #27 movement.
    Thanks for your assistance!
    Gary Gunther
    Default Re: Ingraham Mantle Clock - Movement # 27 (RE: nestordog)
    Gary,
    If you can please post a picture. That would be very helpful.
    Default Re: Ingraham Mantle Clock - Movement # 27 (RE: Jay)
    To go further with Jay's suggestion, we need to see the case and the pendulum, to know.
    Larry Pearson, FNAWCC* #35863
    Default Re: Ingraham Mantle Clock - Movement # 27 (RE: lpbp)
    Most of the mantel clocks by Ingraham use a 2.2 oz. bob. Timesavers has them. As mentioned though, we could verify with a pic or two.
    Default Re: Ingraham Mantle Clock - Movement # 27 (RE: shutterbug)
    Quote Originally Posted by shutterbug View Post
    Unless it's a kitchen clock.
  6. #6
    Where did you find the number 27?
  7. #7
    Default Re: Ingraham Mantle Clock - Movement # 27 (RE: Len Lataille)
    Quote Originally Posted by Len Lataille View Post
    Yes, exactly. If the "27" is on the front plate, to the right of the handshaft, that would be the year the movement was made (the month would be to the left). That date would suggest possibly a tambour, a late black mantle, or possibly a late cabinet clock. In these cases, shutterbug's suggestion of a 2.2 oz. pendulum bob would probably be what is needed.
    “If one tells the truth, one is sure, sooner or later, to be found out.” - Oscar Wilde
  8. #8
    You would think he found it right after the number 26 ??
    H/C
    "There is all the difference in the world between treating people equally and attempting to make them equal." WWW.Heritage-Clocks.com
  9. #9
    Default Re: Ingraham Mantle Clock - Movement # 27 (RE: Heritage-Clocks)
    I also suspect it was before number 28?
    That's a good one, H/C:cyclops:
    My chuckle for the day. It's what happens when the fingers are faster than the brain.
  1. Ingraham - Palace clock movement type?
    By Doug Henry in forum Clock Repair
    Last Post: 07-05-2007, 11:49 AM
  2. Looking for an Ingraham mantle clock bazel.
    By Jeff C in forum Clock Repair
    Last Post: 12-25-2005, 08:29 AM
  3. identification/age of Ingraham Mantle clock...
    By Richard T. in forum Clocks General.
    Last Post: 07-26-2005, 01:29 AM
  4. Replies: 8
    Last Post: 06-16-2005, 03:48 PM
  5. Ingraham Mantle Clock
    By Vicki in forum Clocks General.
    Last Post: 02-01-2005, 05:21 PM
