NOTICE Notice: This is an old thread. The last post was 1638 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 9 of 9
    Default HAC table clock. How to turn off the chime?
    Hi all,
    I am a new member and this is my first post in this forum.
    - I have just bought a Hamburg American Clock, the case was made in Sweden (David Brynte & Optisk Affär, Gefle - brass stamp on the back of the case). The clock size is about 30cm x 30 cm. The back of the clock shows W278, 2 arrows, 36 8. I would appreciate very much if you could help me to identify the age of this clock and how rare/common it is.
    - I also do not know how to turn off the chime of this clock. I tried to push down the lever (4), the chime stops, but the lever does not hold there as my hand leave it. Also what are the purposes of big holes (1), (2) and a small hole (3)?
    (In the back side photo, I removed the pendulum for photo taking convenience.)
    Default Re: HAC table clock. How to turn off the chime? (RE: blueman)
    Sorry to say, some of these clocks were not made with the intention of silencing the strike. Leaving the strike train unwound would result in the dropped rack jamming against the snail sooner or later.
    "Experience, Education, & Enjoyment." - Justin A. Olson
    Registered user.
    Oct 2010
    12,094
    Hi
    1 winds the time
    2 winds the chime
    3 might be adjust the speed? It is missing the pendulum!!!
    There was no chime stop switch intended for this clock.
    I might be easier to let the chime run down.
    Registered user.
    Oct 2010
    12,094
    Default Re: HAC table clock. How to turn off the chime? (RE: chimeclockfan)
    Quote Originally Posted by chimeclockfan View Post
    Hi
    Some clocks were designed to operate with the rack fully dropped
    and some were not. In any case, it looks like it has a broken pendulum
    hanger and missing the pendulum.
    Default Re: HAC table clock. How to turn off the chime? (RE: Tinker Dwight)
    Thank you guys. In the back side photo, I removed the pendulum for photo taking convenience. The clock works fine.
  6. #6
    Nov 2002
    38,603
    Welcome to the message board, blueman.
    August 1936 is a likely date for your clock.
    harold bain, Member ch 33
    "If it won't "tick",
    let me "tock" to it"
  7. #7
    Quote Originally Posted by Tinker Dwight View Post
    Hi
    I've seen some clocks like this, but I wasn't sure if this Junghans movement was one that used it.
    If the clock can run fine with the rack dropped, then leaving the train unwound may be okay.
  8. #8
    Registered user.
    Oct 2010
    12,094
    Some times the rack can be tied up with a piece of string or light wire.
  9. #9
    Registered User soaringjoy's Avatar
    Feb 2009
    7,240
    The W278 was made by Junghans during the period from 1935 to 1961,
    June 1938 is correct for your movement.
    The actual movement design is HAC, Junghans used the crossed arrows mark
    or the JH star at will on these.
    Since the movement was cased in Sweden, the small hole might have been intended
    for a different type of movement. The wholesalers often offered a choice of movement.
    Blueman, you can post your country's flag by editing your User Profile, that makes it a
    bit easier for us, since the Message Board is a very international site.
    Jurgen "tempus nostrum"
  1. how to set up the chimes
    By chubbybull in forum Clock Repair
    Last Post: 07-04-2010, 11:20 AM
  2. I think I have turned off the chimes
    By Bessiesboy in forum Clocks General.
    Last Post: 07-04-2009, 04:44 PM
  3. Elgin Atmos style Quartz clock (how-to?)
    By Chris in forum Electric Horology
    Last Post: 01-04-2007, 02:43 PM
  4. Bulova clock, how to tell movement maker?
    By sherri in forum Electric Horology
    Last Post: 08-31-2005, 01:50 PM
  5. W & H Dial => How to clean off the brass face
    By thebatteryman in forum Clock Repair
    Last Post: 06-20-2005, 11:29 PM
