NOTICE Notice: This is an old thread. The last post was 1717 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 7 of 7
    Unhappy Purchased the wrong pendulum for Hermle Grandfather clock movement
    Eeek! This is my first post & I am definitely an absolute tyro at messing about with clock movements. Through luck or perseverance I have managed to get a couple of old movements going & was encouraged by my partner to build a grandfather clock. I bought a Hermle 1161-853 movement & then a moon dial & a pendulum. This was via a great deal in the US (I am in Australia). My problem is that inadvertently, I have managed to buy a pendulum for a 114 cm clock movement when mine is a 94 cm. My question is whether it is possible to simply shorten the longer pendulum, or whether that would be a total no-no. Would greatly appreciate any assistance.
    Apr 2004
    Mesquite, TX
    938
    Default Re: Purchased the wrong pendulum for Hermle Grandfather clock movement (By: ian hamilton)
    Well, unless someone other is familiar with HERMLE nos. we need to know more. Is this a plain pendulum with a brass strip? Is it a fancy lyre pendulum?
    By th' way matey: WELCOME!
    Default Re: Purchased the wrong pendulum for Hermle Grandfather clock movement (By: Scottie-TX)
    I'm guessing just a wooden stick. If so, you should be able to shorten it without too much trouble. Be sure to leave some wiggle room for fine tuning. You can always take more off, but you can't put any back on
    Registered user. Dick Feldman's Avatar
    Sep 2000
    Colorado, usa
    1,757
    The answer to your question is maybe.
    If you are capable of removing 20 cm from the pendulum and the construction of the pendulum allows tastefully removing that length—the answer is probably yes.
    If/when you remove that length, it will likely be best to remove the material from the top of the pendulum. (Move the hook down). Shortening the pendulum may be as simple as sawing a portion of a wooden stick and reattaching the hook. It may be more involved.
    After changing the overall length, you should have enough adjustment with the nut on the bottom of the pendulum bob to make the clock keep time.
    A picture of the pendulum would be of great help.
    Best Regards,
    Dick
    Default Re: Purchased the wrong pendulum for Hermle Grandfather clock movement (By: Dick Feldman)
    Gadzooks. I thought I just replied to all the friendly folk who gave assistance. I am definitely an amateur - not only at clocks, but at message boards as well. The pendulum arrived today & looking at it I think that it would not be too difficult to shorten: the top brass strip is secured onto the twisted wires (it IS a fancy pendulum I am sorry) by 4 screws & is basically clamped via a sort of bridge to the twisted wires. Click image for larger version.
Name:	Screen Shot 2012-07-16 at 3.19.51 PM.jpg
  6. #6
    You COULD shorten it, but I'd call the supplier and see if you can exchange it for the right size. They're usually willing to do that for you.
  7. #7
    Default Re: Purchased the wrong pendulum for Hermle Grandfather clock movement (By: shutterbug)
    For what it's worth, the top is usually held on with 4 screws. If you remove the top a shorter one can be placed onto the lyre portion. I have done this a few times before to get the desired length. The grid is held together in a block which the top screws into. Removing the screws does not mean the pendulum will come apart. If you can't locate a top PM the length of yours and I'll see if I happen to have something shorter.
  1. Is this the correct pendulum for a BAD clock ?
    By ivancooke in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 10-13-2009, 12:33 PM
  2. Hermle grandfather clock movement
    By FredWJensen in forum Clock Repair
    Last Post: 12-23-2008, 08:16 PM
  3. Is this the correct pendulem for this Grandfather clock?
    By terofpa in forum Clocks General.
    Last Post: 01-28-2008, 05:24 PM
  4. Is this the right pendulum for my JUF Angel Clock?
    By kepiting1sg in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 04-26-2007, 04:25 AM
  5. Pendulum for Waterbury Delft clock
    By DenisG in forum Clocks General.
    Last Post: 06-21-2004, 06:27 AM
