Goal: $300, Received: $250.00 (84%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 1844 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Registered user. clockinit2's Avatar
    May 2012
    Los Angeles
    159
    Default Calais 6 inch is my newest acquisition(looks like the hands are soldered on ??
    Hi every one
    this is my latest acquisition just got it today.
    On the inside of the door label says calias 6 inch
    the. E. Ingraham co.
    Bristol, conn. Usa
    manufacturer of clocks and watches
    established 1823
    along with the instruction of operation etc.
    I was wondering ?? The hands looks like they were soldered on. The seller said it did not work but looks like i got it working. One of the door hinge is broken but that is no problem.
    Would any member know what year this one was possibly manufactured.
    Thanks for your help
ID:	134050   Click image for larger version.
ID:	134051   Click image for larger version.
ID:	134052   Click image for larger version.
ID:	134053   Click image for larger version.
    Default Re: Calais 6 inch is my newest acquisition(looks like the hands are soldered on ?? (By: clockinit2)
    A nice cabinet clock. Tran Duy Ly's Ingraham book shows this clock and its companion, the Dover, from the 1934 catalogue. Per the catalogue description, the styles were earlier used for electric clocks. Ingraham was always noted a good cabinet makers, and I believe they also made cabinets for radios, Emerson comes to mind. I could easily see this as a radio cabinet. I happen to own one and find it to be a good time keeper. There was also an earlier style of the Calais shown from the 1923 catalogue. The front of the movement should have date codes, the month on the left of the hand shaft and the year on the right. This is the date the movement was produced but also gives an approximate date for the clock itself.
    It does appear that some has used solder to hold on the minute hand. Pretty sorry repair. There also appears to be heat damage/discoloration to the dial, reinforcing the impression of solder. The dial may need resilvering if the discoloration can not otherwise be cleaned off. The solder should also be removed and a proper fastening used, in this case a threaded nut. You can't, of course, remove the movement for servicing without removing the hands. Maybe the April 14, 1999, date on the door is the date the crime was committed.
    “If one tells the truth, one is sure, sooner or later, to be found out.” - Oscar Wilde
    Registered User soaringjoy's Avatar
    Feb 2009
    7,240
    Default Re: Calais 6 inch is my newest acquisition(looks like the hands are soldered on ?? (By: Steven Thornberry)
    Poor old thing...
    Jurgen "tempus nostrum"
    May 2012
    Los Angeles
    159
    Thanks for the info.
    It does keep time very good. I will try to remove the solder but i am trying to think how without destroying the face or the shaft, because it has to probably get real hot. Maybe with a flat solder iron instead of a torch.
    May 2012
    Los Angeles
    159
    Thank you very much.
    I have a question I would like to ask.
    Do anyone know where I can find a door hinge, because one of the door hinge is broken , thats why I removed the door , so as not to break the other hinge. Thanks your info on the door hinge would be greatly appreciated. Thanks
  6. #6
    Registered user. Russell Dickson's Avatar
    Dec 2011
    New York
    460
    Default Re: Calais 6 inch is my newest acquisition(looks like the hands are soldered on ?? (By: soaringjoy)
    Quote Originally Posted by soaringjoy View Post
    Poor old thing...
    lol
  7. #7
    Apr 2002
    20,130
    Blog Entries
    Default Re: Calais 6 inch is my newest acquisition(looks like the hands are soldered on ?? (By: Russell Dickson)
    Good candidate for the hall of shame, nice clock otherwise.
  8. #8
    Default Re: Calais 6 inch is my newest acquisition(looks like the hands are soldered on ?? (By: Kevin W.)
    Someone at some time soldered those hands and did little or no perceptible damage to the dial.Are there not pads or material that reflect heat that could be cut to fit and carefully surround the cannon and protect ths dial?
    Bruce
    Es mejor morir de pie, que vivir de rodillas.....Emiliano Zapata Salazar
  9. #9
    Registered user.
    Apr 2011
    Arvada, CO
    104
    Default Re: Calais 6 inch is my newest acquisition(looks like the hands are soldered on ?? (By: Bruce Barnes)
    A heat shield can be easily be fabircated from an aluminum soda can. Cut off the top and bottom of the soda can.
    Then cut the can body open and press flat. Now cut a slot to accept the center shaft of the clock.
    Place this shield between the clock face and the hands.
    Use a 100W or larger soldering iron to melt the solder and remove the hands.
    Now you can use any clean up procedure to remove any remaining solder from both the hand shafts and the hands themselves.
    DO NOT USE A TORCH unless you have prior experience using a torch for delicate soldering.
    Regards
    John
  10. #10
    Dec 2011
    Brockville, On Canada
    5,674
    Default Re: Calais 6 inch is my newest acquisition(looks like the hands are soldered on ?? (By: jcosta-co)
    To remove as much solder as possible a solder sucker and or solder wick is helpful
    David S
  11. #11
    Dec 2011
    New York
    460
    Quote Originally Posted by Bruce Barnes View Post
    Bruce
    looks like the heat damage is alreay done, I would worry about it too much you couldn't possibly make it much worse. I would look into finding a new dial or having that one restored.
  12. #12
    May 2012
    Los Angeles
    159
ID:	137840Click image for larger version.
ID:	137841Click image for larger version.
  13. #13
    Russell I agree with you regarding damage to the dial to a point,i.e.,the numbers still retain most of their color,the dial pan is not distorted or warped,the dial signature is still visible maybe some of the discoloration outside the chapter ring could possibly be cleaned.
    Bruce
  14. #14
    May 2012
    Los Angeles
    159
    I made the piece that was broken to repair the hinge.
    The part with blue tape is the broken one . I taped it so that I can mark out the shape on the piece of .025 inch brass stock.
    Cut and file and bend to shape fit.
ID:	139966Click image for larger version.
ID:	139967Click image for larger version.
ID:	139968Click image for larger version.
ID:	139969Click image for larger version.
  15. #15
    Quote Originally Posted by clockinit2 View Post
    Nicely done.
  1. Is my New Acquisition Anything?
    By JST in forum Clocks General.
    Last Post: 09-06-2009, 11:35 AM
  2. Replies: 26
    Last Post: 06-03-2009, 10:53 PM
  3. My Newest Acquisition
    By LarFure in forum American Pocket Watches
    Last Post: 10-13-2008, 06:32 AM
  4. My newest acquisition and a question
    By RLM in forum Clocks General.
    Last Post: 06-21-2008, 08:35 AM
  5. The movment is engraved with what looks like two towers
    By Kent in forum American Pocket Watches
    Last Post: 06-16-2005, 12:24 AM
