Goal: $300, Received: $280.00 (94%) Contribute Now
NOTICE Notice: This is an old thread. The last post was 1706 days ago. If your post is not directly related to this discussion please consider making a new thread.
Page 1 of 2 12 LastLast
Results 1 to 15 of 28
    Default Swing Ring Cases - when were they introduced, and why?
    Well the title says it all really, when were Swing Ring Cases, the type where the bezel unscrews and the movement flips out on a hinge, introduced, and what was the purpose of the "swing" bit, why was the hinge there? Was it so that the owner could flip the movement out to regulate it and have less chance of dropping it than it it simply sat in the case? I can't really see that the hinge adds much apart from cost.
    Any thought gratefully appreciated.
    Regards - David
    Default Re: Swing Ring Cases - when were they introduced, and why? (RE: DavidBoettcher)
    I don't know why they offered that style, but I just had to rebuild the hinge on one yesterday. Both pieces of the hinge were broken off, it came out perfect. I enjoy restoring pocket watches to thier original condition.
    Very rewarding.
    I don't see that it was a design for the owner, since it is much more difficult for them to open.
    An O pinion to start...
    The origin would date back to the key wind days...
    IMHO, the main purpose was to have a case that was more resistant to dust intrusion.
    A specific answer about why did it 'swing'...
    1. to allow the case screws to be tightened
    2. yes, allow regulation
    I don't know for sure but believe produced concurrently there would have been the 'pair' case or other variant (gem) where the movement center ring
    lifted out of the outer housing.
    Chapter 17 North Carolina
    http://www.nawcc-carolina17.org/default.htm
    Chapter 149 Early American Watch Club .. Home of Russ Snyder Illinois CD database and Henry Burgell Serial number Look-up ... excellent research resources!
    http://www.nawcc-ch149.com/ http://www.nawcc-ch149.com/pw_dbresearch.html
    Chapter 149 Mentor List http://www.nawcc-ch149.com/mentor.html
    Smile Re: Swing Ring Cases - when were they introduced, and why? (RE: terry hall)
    Swing Ring cases date back to at least as early as 1884, evidenced by this Fahys ad. Perhaps somebody else can find an earlier listing for one.
    I suspect two possible reasons for the hinge. One might be to fasten the movement ring more firmly in the case than was possible with the lift-out style that was also available in the 1880s, as seen in this B&B 1885 ad.
    Another reason may have been to avoid patent infringement.
    Kent
    That guy down in Georgia
    Registered User Norman Bliss's Avatar
    Jan 2005
    Springfield, Hampden Co.
    214
    Default Re: Swing Ring Cases - when were they introduced, and why? (RE: terry hall)
    Swing ring cases are more dust/dirt proof because they only have one joint, and the ring itself encloses the movement serving as additional dust protection. All the ones I own or have seen have an extra dust washer, felt or what ever, under the crown to keep dust from getting into the movement from the stem. See the brass ring under the crown on my Hamilton 972 in a nickel Crescent case. There's a felt washer in there. These were popular for watches in RR service. Watch inspectors may also have liked them because they discouraged owners from opening them.
    Norman Bliss
  6. #6
    Default Re: Swing Ring Cases - when were they introduced, and why? (RE: Norman Bliss)
    Hi Norman,
    That's interesting, especially the information about the felt washers.
    I take you point about the ring circling the movement keeping dust out, in Swiss watches a similar ring is sometimes called a "cercle cache-poussiŤre" which means something like circular dust guard. But it doesn't need to be hinged to do that function.
    And thanks to Kent for the links to the adverts - 1884 is plenty early enough for my purposes.
    Regards - David
  7. #7
    Jan 2005
    214
    David, dust rings were also used on American watches in American cases, but not always, and could be lost or left out during service. RR watches were supposed to be regulated by watch inspectors, so there was no need for the owner to get at the back of the movement, and every reason to discourage him from doing so. With the washer around the stem, swing ring cases were more resistant to moisture, although certainly not 'waterproof'.
    Norman Bliss
  8. #8
    Registered User doug sinclair's Avatar
    Aug 2000
    Calgary, Alberta
    14,199
    Blog Entries
    How much of a contribution has the swing ring case made to the problem of broken fourth wheel arbors?
  9. #9
    Quote Originally Posted by Norman Bliss View Post
    That's a good point, the hinge would certainly stop it getting lost.
  10. #10
    Default Re: Swing Ring Cases - when were they introduced, and why? (RE: doug sinclair)
    Quote Originally Posted by doug sinclair View Post
    Hi Doug, I'm sure it's a good question, but it's Greek to me . . . .
    Regards - David
  11. #11
    Jan 2005
    214
    Well, the case I showed was my introduction to that problem. Bought it online, it arrived with the second hand loose in the case--with the tip of the 4th wheel arbor still in it. The seller made it good however. David, the danger of a swing ring case is that when you try to pry it up by the 6, you can slip and hit the second hand, bending or breaking the extended 4th wheel arbor that it's on. Another danger is if you don't pull out the stem when swinging out the ring you'll bend the stem.
    Norman Bliss
  12. #12
    Clear as crystal. Thanks Norman.
    Regards - David
  13. #13
    Jul 2009
    Kentucky
    2,679
    Although not exactly the same thing, I've always seen some resemblance between American swing-ring cases and the typical construction of the inner case of an English pair-case watch. For these cases, the movement anchored to the case by a hing at 12:00 and a catch at 6:00. To view the movement, the catch at 6:00 is pressed, and the movement lifts out of the case by the hinge.
  14. #14
    Aug 2000
    Calgary, Alberta
    14,199
    Blog Entries
    Default Re: Swing Ring Cases - when were they introduced, and why? (RE: ben_hutcherson)
    David,
    The lip you catch with a finger nail to lift open the swing ring is at the 6:00 position. About 1/2 inch away from the seconds hand! If you are not really a careful opening the swing ring, your finger nail can slip and catch the seconds hand! Ever notice how often someone on the MB is looking for a replacement fourth wheel?
  15. #15
    It appears that Ezra C. Fitch, former president of Waltham Watch Co., patented the Swing-Ring case in 1879. See the patent below........
    Robert
    Attached Thumbnails Attached Thumbnails Swing-Ring Case- Patent -1879.pdf
  1. Hinge Back & Bezel cases, pros and cons and were they popular?
    By Vsanzbajo in forum American Pocket Watches
    Last Post: 05-05-2012, 06:47 PM
  2. swing-ring case
    By guychampeau in forum Watch Repair
    Last Post: 12-07-2010, 10:54 AM
  3. Replies: 1
    Last Post: 12-30-2002, 03:00 AM
  4. swing ring case
    By crsides in forum American Pocket Watches
    Last Post: 11-08-2002, 07:04 AM
  5. Hamilton 992, When did they start casing at factory?
    By Cary in forum American Pocket Watches
    Last Post: 05-06-2002, 04:09 AM
