Goal amount for this month: 300 USD, Received: 230.00 USD (77%) Contribute Now
Donate whatever you can or Join the 16,000 other NAWCC members for only $72 (plus $10 for hard copy publications). Check it out here.
NOTICE Notice: This is an old thread. The last post was 432 days ago. If your post is not directly related to this discussion please consider making a new thread.
Results 1 to 6 of 6
    Question Bent suspension springs (newbie question)
    Some of my clocks suspension springs in my collection appear to have a definite bend put into them ie they are not straight.
    I have an example of a fairly new suspension on a vienna movement with a slight bend put into the suspension - I assume done by the previous owner and not by accident.
    Couldn't see any reference in my clock repair book but I was reading on a sellers site that suspension springs are only there to support the pendulum and should not be doing anything else?.
    So for what reason(s) should a suspension need a bend in it?
    Cheers
    Default Re: Bent suspension springs (newbie question)
    A suspension spring should be straight, the bent on the spring in the picture is due to a rough removal of the pendulum. If the pendulum doesn`t wobble you don`t have to replace the suspension spring.
    Registered User shutterbug's Avatar
    Oct 2005
    19,995
    If it's not kinked, you can usually straighten it back out without problems.
    thanks for the replies. I will get the suspension straightened out.
    Registered User Scottie-TX's Avatar
    Apr 2004
    Mesquite, TX
    8,973
    Yeah - that particular type of bend should not cause a problem. Simply pull on it lightly while urging bend in opposite direction til straight. It is bends and kinks in the ribbon itself that cause the biggest problems. That's not the case here.
  6. #6
    Quote Originally Posted by Scottie-TX View Post
    many thanks
  1. Suspension spring - theoretical question
    By DianneB in forum Clock Repair
    Last Post: 03-17-2012, 08:43 PM
  2. suspension spring installation question
    By TexasTim in forum Clock Repair
    Last Post: 07-21-2011, 06:12 PM
  3. Suspension spring assembling question
    By hoo-boy in forum 400-Day, Atmos and other Torsion Clocks
    Last Post: 02-09-2010, 06:36 AM
  4. Suspension spring replacement question
    By bunratty4 in forum Clock Repair
    Last Post: 01-30-2010, 12:54 PM
  5. Clock Help For Newbie, Involves Suspension Spring
    By MagnumD in forum Clock Repair
    Last Post: 02-11-2006, 07:29 AM
